Unable to view stl geometry in paraview after snappyHexMesh |
November 18, 2020, 11:22 |
Pratik
Rep Power: 6 |
Hello
I am running a cfd simulation for vertical axis wind turbine. I have attached the geometry. I have also attached the SHM file. I ran SHM and afterwards when I check in paraview, I don't see my geometry. I have also attached the SHM log file. Thank you Pratik Last edited by Pratik Wani; March 3, 2021 at 05:42. |
November 20, 2020, 00:22 |
Solved
Pratik
Rep Power: 6 |
Hello
I figured it out. I forgot to run "reconstructParMesh -constant" before checking in paraview. |
[CAD formats] stl geometry is not close | ignacio.12 | OpenFOAM Meshing & Mesh Conversion | 7 | June 24, 2020 13:13 |
[snappyHexMesh] SHM does not follow STL geometry well | Illmatic | OpenFOAM Meshing & Mesh Conversion | 7 | July 23, 2016 11:07 |
opensource geometry for snappyHexMesh | Naresh yathuru | OpenFOAM Pre-Processing | 2 | March 9, 2015 03:18 |
[Workbench] Meshing and export mesh from STL geometry | alerfreire | ANSYS Meshing & Geometry | 0 | March 26, 2013 09:25 |
[snappyHexMesh] Paraview and snappyhexmesh help needed | basilwatson | OpenFOAM Meshing & Mesh Conversion | 0 | November 9, 2009 09:13 |
