Periodic Boundary Condition For The Edges of Parallelogram |
May 18, 2020, 03:19 |
Duc Anh
Rep Power: 7 |
hi foamer,
I want to define 4 cyclics boundary for 4 edges of the parallelog channel. But I have a problem with 2 edges which were tilted against the axis (look at the picture below). I was used gmsh to meshing and used createPatchDict to create cyclic boundary. Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object createPatchDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Do a synchronisation of coupled points after creation of any patches. // Note: this does not work with points that are on multiple coupled patches // with transformations (i.e. cyclics). pointSync false; // Optional: Write cyclic matches into .obj format; defaults to false. writeCyclicMatch false; // Patches to create. patches ( { //- Master side patch name in_1; patchInfo { type cyclic; matchTolerance 0.0001; neighbourPatch out_1; transform translational; separationVector (8e-6 0 0) ; } constructFrom patches; patches (in1); } { //- Slave side patch name out_1; patchInfo { type cyclic; matchTolerance 0.0001; neighbourPatch in_1; transform translational; separationVector (-8e-6 0 0); } constructFrom patches; patches (out1); } { //- Master side patch name in_2; patchInfo { type cyclic; // inGroups 1(cyclicAMI); matchTolerance 0.0001; neighbourPatch out_2; transform translational; separationVector (0 -8e-6 0 ) ; } constructFrom patches; patches (in2); } { //- Slave side patch name out_2; patchInfo { type cyclic; // inGroups 1(cyclicAMI); matchTolerance 0.0001; neighbourPatch in_2; transform translational; separationVector (0 8e-6 0 ); } constructFrom patches; patches (out2); } ); patch:in_2 my area:1e-13 neighbour area:8e-14 matching tolerance:0.0001 " I was tried cyclicAMI but it is not fit in my solver which I was developed. Any one help me to create cyclic boundary for these edge. Thank you so much, |
cyclic boundary condition, gmsh 4.0.4 |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Speed problem of periodic boundary condition imposed on pitching airfoil. | TG777 | OpenFOAM Running, Solving & CFD | 1 | March 20, 2020 16:33 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
