Create two regions based on surrounding surfaces |
June 3, 2020, 11:56 |
Matt Schramm
I am making two regions for a simulation and would like to know if it would be possible to define the two regions based on their surrounding surfaces. Say I have two rectangles fused together (see image) and I would like all cells normal and above of S1 to be in R1 and all cells normal and above of S2 to be in R2. Would this be possible? If not, is there a way to get variables from a separate file and use them in topoSetDict? I ask because I will be doing multiple simulations with slightly different geometry for each and the less I have to remember to edit the better. Thank you |
toposet |
[Other] splitMeshRegions does not create interface patch between regions | fsan | OpenFOAM Meshing & Mesh Conversion | 10 | June 6, 2022 05:56 |
[mesh manipulation] How to create a mesh with solid cylinder and air/fluid surrounding it for openfoam | bharadwaz | OpenFOAM Meshing & Mesh Conversion | 4 | August 26, 2019 16:02 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[snappyHexMesh] Mixed snappyHexMesh+Fluent case: create new surfaces on existing CAD file | thomas. | OpenFOAM Meshing & Mesh Conversion | 0 | May 28, 2016 12:22 |
how to create iso surfaces | shaktinaik | FLUENT | 0 | November 15, 2015 05:28 |
