Simulation of pressure line discharge in a turbulent model
Old   June 22, 2020, 20:49
Question Simulation of pressure line discharge in a turbulent model
Martin Felipe Ramirez Muņoz
Martin Ramirez is on a distinguished road
I thank you for entering this publication.
The context of my concern is as follows, I want to simulate the discharge of a pressure pipe on a hydraulic structure and observe the interaction that occurs with a pipe at the outlet for open flow conditions, initially create a mesh of the structure and pipe in conjunction with an elbow as accessory for the discharge at the entrance, in the SALOME 9.3 software, creating the mesh of the faces of 'wall-elbow', 'Atmosphere', 'wall-solid', 'Inlet' and 'Outlet' In geometry, two objects were merged, which were an inspection box with their respective pipes and an elbow. The mesh was imported into OpenFOAM through the ideasUnvToFoam intermediary which allows to bring the unv file to a representation of 'polyMesh'. For which the 'boundary' file is built, which contains 6 faces, taking the output and input of the elbow as 'defaultFaces', which are modified with an 'empty' value so that they do not have an interaction within the simulation.
FoamFile
        version            2.0;
        format             ascii;
        class                polyBoundaryMesh;
        location            "constant/polyMesh";
        object               boundary;
6
        wall-elbow
              type           wall;
              nFaces        290;
              startFace     581153;
         Atmosphere
              type           patch;
              nFaces        290;
              startFace     581153;
          wall-solid
              type           wall;
              nFaces        290;
              startFace     581153;
          Inlet
              type           patch;
              nFaces        290;
              startFace     581153;
          Outlet
              type           patch;
              nFaces        290;
              startFace     581153;
           defaultFaces
              type           empty;
              nFaces        290;
              startFace     581153;
Once the analysis mesh was imported, we proceeded to configure 'system', for which 'setFieldsDict' was edited, which expressed the regions with an alpha value of 1 for a section of cylindrical geometry, taking the radius and position of the entry.
FoamFile
        version            2.0;
        format             ascii;
        class                dictionary;
        location            "system";
        object              setFieldsDict;
defaultFieldValues
       volScalarFieldValue alpha.water 0
regions
        cylinderToCell
             p1 (0.40 -1 0.40);         // center of first circle
             p2 (0.40 0 0.40);          // center of second circle
             radius 0.04021;            // radius of cylinder
             fieldValues
                  volScalarFieldValue alpha.water 1
The solver used to analyze the boundary conditions, properties of the fluid and the physics of the flow, is carried out by means of 'interFoam', taking the inlet pipe with a full tube analysis (that is, it contains only water), the discharge of the fluid on the bottom of the structure and its drainage to the outlet pipe it is taken as a relation of multiphase fluids where air and water interact. The physics of the flow is observed with the appreciations of turbulent flow, for this reason the K-Omega model is used, it solves the RAS equation by means of 'PIMPLE'.
FoamFile
        version            2.0;
        format             ascii;
        class                dictionary;
        location            "system";
solvers
       "alpha.water.*"
             nAlphaCorr             1;
             nAlphaSubCycles     1;
             cAlpha                    1;
             MULESCorr              yes;
             nLimiterIter             3;
             solver                      smoothSolver;
             smoother                 symGaussSeidel;
             tolerance                 1e-8;
             relTol                       0;
         pcorrFinal
             solver             PCG;
             preconditioner
                    preconditioner         GAMG;
                    tolerance                  1e-5;
                    relTol                        0;
                    smoother                GaussSeidel;
                    nPreSweeps              0;
                    nPostSweeps             2;
                    nFinestSweeps           2;
                    cacheAgglomeration    true;
                    nCellsInCoarsestLevel       10;
                    agglomerator              faceAreaPair;
                    mergeLevels               1;
               tolerance      1e-5;
               relTol            0;
               maxIter        50;
         p_rgh
                    solver                    GAMG;
                    tolerance                 5e-9;
                    relTol                       0.01;
                    nPreSweeps            0;
                    nPostSweeps           2;
                    mergeLevels            1;
                    maxIter                   50;
            p_rghFinal
                    $p_rgh;
                    tolerance                  5e-9;
                    relTol                        0;
             "(U|k|omega).*"
                    nSeewps                   1;
                    tolerance                   1e-6;
                    relTol                         0.1;
PIMPLE
             momentumPredictor           no;
             nCorrectors                          2;
             nNonOrthogonalCorrectors    0;
relaxationFactors
             equations
                    ".*"  1;
The determination of the VOF started from the methodology that establishes alpha.water 1 for the value of water and 0 for the value of air, for this purpose the entrance was taken as a uniform value of 1, the walls were established with the type 'zeroGradient'.
FoamFile
        version            2.0;
        format             ascii;
        class                volScalarField;
        location            "0";
        object               alpha.water;
dimensions                [0 0 0 0 0 0 0]
internalField               uniform 0;
boundaryField
        Inlet
              type             fixedValue;
              value            uniform 1;
        wall-solid
              type              zeroGradient;
        wall-elbow
              type               zeroGradient;
        Outlet
              type               zeroGradient;
              value              uniform 0;
        Atmosphere
               type               inletOutlet;
               inletValue       uniform  0;
               value             uniform   0;
The velocity value corresponds to an inlet flow to pressure pipe of 0.20 m3 / s.
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 2.29 0);
boundaryField
    Inlet
	type            flowRateInletVelocity;
        volumetricFlowRate constant 0.20;
    wall-solid
	type            fixedValue;
        value           uniform (0 0 0);
    Atmosphere
        type            pressureInletOutletVelocity;
    Outlet
	type            inletOutlet;
        inletValue      uniform (0 0 0);
        value           $internalField;
    wall-elbow
        type            fixedValue;
For the pressure two moments are established, the first is the discharge pressure of the inlet pipe and the second is the atmospheric pressure.
FoamFile
    version     2.0;
    format      ascii;
    object      p_rgh;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 78451.04;
boundaryField
    Atmosphere
        type            totalPressure;
        p0              uniform 101325;
        U               U;
        phi             phi;
        rho             rho;
        psi             none;
        gamma           1;
        value           uniform 101325;
    Outlet
         type            zeroGradient;
    Inlet
        type            fixedFluxPressure;
        value           uniform 78451.04;
The turbulence energy value is taking into account the turbulence intensity for the hydraulic diameter.
FoamFile
    version     2.0;
    format      ascii;
    object      k;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0.00969;
boundaryField
    Inlet
        type            fixedValue;
        intensity       0.0351;
    wall-solid
        type            kqRWallFunction;
    wall-elbow
        type            inletOutlet;
        inletValue      $internalField;
        value           $internalField ;
The dissipation of energy is taken using the omega model, for this the length of the turbulence is used.
FoamFile
    version     2.0;
    format      ascii;
    object      omega;
dimensions      [0 0 -1 0 0 0 0];
internalField   uniform 32.22;
boundaryField
    Inlet
        type            fixedValue;
    wall-solid
        type            omegaWallFunction;
    wall-elbow
        type            inletOutlet;
The nut value is set for the input and output conditions.
    version     2.0;
    format      ascii;
    location    "0";
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
boundaryField
    wall-solid
        type            nutkWallFunction;
        value           uniform 0;
    wall-elbow
	value		uniform 0;
        type            calculated;
        value           uniform 0;
The turbulence properties are analyzed by means of the RAS equations solved with the k-omega model.
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      turbulenceProperties;
simulationType  RAS;
RAS
    RASModel        kOmegaSST;
    turbulence      on;
    printCoeffs     on;
The properties of the fluids follow the density, viscosity, and surface tension conditions for air and water.
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      transportProperties;
phases (water air);
water
    transportModel  Newtonian;
    nu              [0 2 -1 0 0 0 0]  1e-06;
    rho             [1 -3 0 0 0 0 0] 1000;
air
    nu              [0 2 -1 0 0 0 0]  1.48e-05;
    rho             [1 -3 0 0 0 0 0] 1;
sigma           [1 0 -2 0 0 0 0] 0.07;
The gravity value is specified as 9.81 m / s2
FoamFile
    version     2.0;
    format      ascii;
    class       uniformDimensionedVectorField;
    object      g;
dimensions      [0 1 -2 0 0 0 0];
value           (0 0 -9.81);
To establish the Courant number, a deltaT value of 0.0000001 was used.
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     interFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         10;
deltaT          0.0000001;
writeControl    adjustableRunTime;
writeInterval   0.05;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression compressed;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
adjustTimeStep  yes;
maxCo           6;
maxAlphaCo      6;
maxDeltaT       1;
functions
    inletFlux
        type            faceSource;
        functionObjectLibs ("libfieldFunctionObjects.so");
        outputControl   timeStep;
        log             true;
        // Output field values as well
        valueOutput     false;
        source          patch;
        sourceName      Inlet;
        operation       sum;
        fields
            rhoPhi
    OutletFlux
        $inletFlux;
        sourceName      Outlet;
    AtmosphereFlux
        $inletFlux;
        sourceName      Atmosphere;
Once the 'interFoam' solver is executed, an error is generated in the model's journey based on the loaded conditions and characteristics, the stability of the system is damaged.
Courant Number mean: 0.00202408 max: 0.0216337
Interface Courant Number mean: 0 max: 0
deltaT = 7.19942e-06
Time = 7.19942e-06
smoothSolver:  Solving for alpha.water, Initial residual = 1.79803e-06, Final residual = 4.27735e-12, No Iterations 1
Phase-1 volume fraction = 0.00838449  Min(alpha.water) = 0  Max(alpha.water) = 1
MULES: Correcting alpha.water
Phase-1 volume fraction = 0.00838449  Min(alpha.water) = -1.61933e-13  Max(alpha.water) = 1
GAMG:  Solving for p_rgh, Initial residual = 1, Final residual = 1.24433e+37, No Iterations 50
time step continuity errors : sum local = 1.71056e+34, global = -5.28206e+32, cumulative = -5.28206e+32
GAMG:  Solving for p_rgh, Initial residual = 1, Final residual = 4.3059e-09, No Iterations 19
time step continuity errors : sum local = 1.42133e+59, global = 7.45096e+58, cumulative = 7.45096e+58
smoothSolver:  Solving for omega, Initial residual = 0.811838, Final residual = 0.0685701, No Iterations 7
smoothSolver:  Solving for k, Initial residual = 0.999997, Final residual = 0.0973059, No Iterations 40
bounding k, min: 8.78028e-62 max: 0.0785186 average: 0.00967384
ExecutionTime = 12.45 s  ClockTime = 14 s
Courant Number mean: 1.10307e+67 max: 2.31367e+69
deltaT = 1.86701e-74
Time = 7.19942e-06
smoothSolver:  Solving for alpha.water, Initial residual = 1.2844e-08, Final residual = 2.55005e-13, No Iterations 1
Phase-1 volume fraction = 0.00838449  Min(alpha.water) = -7.91099e-14  Max(alpha.water) = 1
Phase-1 volume fraction = 0.00838449  Min(alpha.water) = -2.03375e-12  Max(alpha.water) = 1
GAMG:  Solving for p_rgh, Initial residual = 1, Final residual = 0.00547086, No Iterations 5
time step continuity errors : sum local = 2.88229e-05, global = -1.51418e-06, cumulative = 7.45096e+58
GAMG:  Solving for p_rgh, Initial residual = 0.310287, Final residual = 4.13946e-09, No Iterations 37
time step continuity errors : sum local = 4.48349e-11, global = 4.75626e-12, cumulative = 7.45096e+58
smoothSolver:  Solving for omega, Initial residual = 0.00265864, Final residual = 3.78146e-05, No Iterations 1
smoothSolver:  Solving for k, Initial residual = 2.73075e-06, Final residual = 9.66491e-11, No Iterations 1
ExecutionTime = 16.4 s  ClockTime = 18 s
Courant Number mean: 0.0109246 max: 3.60706
deltaT = 2.17757e-74
Time = 7.19942e-06
smoothSolver:  Solving for alpha.water, Initial residual = 5.45264e-09, Final residual = 5.45264e-09, No Iterations 0
GAMG:  Solving for p_rgh, Initial residual = 0.399741, Final residual = 0.00178865, No Iterations 5
time step continuity errors : sum local = 2.75265e-05, global = -1.45885e-06, cumulative = 7.45096e+58
GAMG:  Solving for p_rgh, Initial residual = 0.296846, Final residual = 0.00128416, No Iterations 50
time step continuity errors : sum local = 1.17308e-05, global = -3.1497e-07, cumulative = 7.45096e+58
smoothSolver:  Solving for omega, Initial residual = 0.00213625, Final residual = 2.79442e-05, No Iterations 1
smoothSolver:  Solving for k, Initial residual = 0.000438583, Final residual = 9.42752e-08, No Iterations 1
bounding k, min: 2.22045e-16 max: 0.0785185 average: 0.00967385
ExecutionTime = 21.27 s  ClockTime = 23 s
Bearing in mind the context of the simulation and its errors, I would like to know your opinions regarding this situation and the possible bibliographic reviews that I must carry out to change, improve or configure the solution.
Thank you.
Martin Ramirez
Martin Ramirez is offline   Reply With Quote
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
High pressure nitrogen discharge simulation in Fluent jzapatau FLUENT 0 October 2, 2016 17:54
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
