August 25, 2020, 12:16 |
Problem with snappyhexmesh and layers
TWB
Rep Power: 19 |
I'm trying to generate mesh for a 3d wing. I also wanted to add layers to resolve the viscous forces. However, the mesh I got look quite bad. My configuration is as follows below. What must I change to get the layers surrounding the wall to be "nice"? Code:
addLayersControls { // Are the thickness parameters below relative to the undistorted // size of the refined cell outside layer (true) or absolute sizes (false). relativeSizes false; // Per final patch (so not geometry!) the layer information layers { //"(wing).*" wing_wall { nSurfaceLayers 3; } } // Expansion factor for layer mesh expansionRatio 1.2; // Wanted thickness of final added cell layer. If multiple layers // is the thickness of the layer furthest away from the wall. // Relative to undistorted size of cell outside layer. // See relativeSizes parameter. firstLayerThickness 2e-5; // Minimum thickness of cell layer. If for any reason layer // cannot be above minThickness do not add layer. // Relative to undistorted size of cell outside layer. minThickness 0.1; Last edited by quarkz; August 25, 2020 at 19:57. |
August 25, 2020, 22:06 |
Ardalan
Rep Power: 13 |
Make the background mesh finer and make the resolution regionally finer. increase the number of refinement in 'refinementBox'. Good luck Ardalan |
August 31, 2020, 23:09 |
TWB
Rep Power: 19 |
Ok I will try, thanks!
[snappyHexMesh] Problem with skewd faces in SnappyHexMesh | Friendly | OpenFOAM Meshing & Mesh Conversion | 1 | June 19, 2019 07:05 |
[snappyHexMesh] Problem in results with snappyHexMesh between refinement levels | Phil_WO | OpenFOAM Meshing & Mesh Conversion | 2 | November 8, 2018 03:49 |
[snappyHexMesh] Old and busted: snappyHexMesh and add layers with edges | Siassei | OpenFOAM Meshing & Mesh Conversion | 6 | August 14, 2018 18:33 |
[snappyHexMesh] Triangular elements in boundary layers generated by snappyHexMesh | mike.franky | OpenFOAM Meshing & Mesh Conversion | 0 | June 3, 2018 09:46 |
[snappyHexMesh] 2D snappyHexMesh with layers | grjmell | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2013 12:00 |
