September 23, 2020, 12:38 |
BC's problem
andrea chianese
Rep Power: 6 |
Hi everyone,
I am a new member and i have a problem with the BC setting. I'll try to explain my situation: this is a stationary - laminar simulation performed on an airbox. this geometry contains 2 inlets and 4 outlets. the purpose of the simulation is to obtain the pressure value at the outlets. My BC setting is this: Inlet: p: type totalPressure; p0 uniform 84452.32; U: type zeroGradient; Outlet: p: type zeroGradient; U: type flowRateOutletVelocity; massFlowRate constant 0.0402778; rhoOutlet 1.1841; with this setting I have a "timestep continuity error" problem. this value increases with each timespet. does anyone know if the bc setting is correct? P.S. - The same simulation done with starccm+ reported me about the backflow to the inlet. - the mesh was done with HappyHexMesh and checkMesh told me that it's all ok. - sorry for my bad english |
Problem with rotating and non rotating bc's in SRFSimpleFoam and MRFSimpleFoam | jcespada | OpenFOAM Running, Solving & CFD | 2 | May 13, 2015 10:39 |
[Commercial meshers] Problem with cyclic BC's using Pointwise (non-orthogonality error!) | Dan1788 | OpenFOAM Meshing & Mesh Conversion | 1 | November 17, 2014 15:23 |
Can I solve this problem by Fluent? | Kai_kc | FLUENT | 1 | October 27, 2010 05:29 |
Velocity profiles problem behind the elbow (3D problem) | kabat73 | FLUENT | 8 | May 9, 2010 04:26 |
problem in setting up BC's | san | FLUENT | 0 | April 26, 2006 01:34 |
