Transient - how an object about a pivot is effected by the fluid flow?
Old   October 1, 2020, 05:43
Question Transient - how an object about a pivot is effected by the fluid flow?
Spacehorse is on a distinguished road
Hi All,
I would like to run a simulation to find out how an object that can pivot around a fixed point will be effected by a fluid flow (water).
The object has mass and so a moment about the pivot point, I would like to see at which angle the object will be in equilibrium at different velocities due to the weight and moment of the frame and the lift and moment from the fluid flow becoming equal. please see attached diagram.
it would be good to see the frame pivot and stabilise in the post processing. but maybe this sim would also be possible as steady-state?
anyway I'm looking for some advice on where to start with this one. Does anyone know any tutorials that I could build my case from?
I don't know how to have the geometry pivot about a fixed point and be able to move during the simulation.
Any help would be great thank you!
Spacehorse is offline   Reply With Quote
moving geometry, pivot point
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
Fluid flow from a pipe Raza Javed OpenFOAM Running, Solving & CFD 44 July 25, 2019 08:53
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
