FOAM FATAL ERROR: Unable to find initial target face
Old   October 27, 2020, 11:06
Default FOAM FATAL ERROR: Unable to find initial target face
ESI
ht2017 is on a distinguished road
Dear Foamer,
Now, I am facing the issue with OpenFOAM extent 4.0
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  8
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      createPatchDict;
// This application/dictionary controls:
// - optional: create new patches from boundary faces (either given as
//   a set of patches or as a faceSet)
// - always: order faces on coupled patches such that they are opposite. This
//   is done for all coupled faces, not just for any patches created.
// - optional: synchronise points on coupled patches.
// - always: remove zero-sized (non-coupled) patches (that were not added)
// 1. Create cyclic:
// - specify where the faces should come from
// - specify the type of cyclic. If a rotational specify the rotationAxis
//   and centre to make matching easier
// - always create both halves in one invocation with correct 'neighbourPatch'
//   setting.
// - optionally pointSync true to guarantee points to line up.
// 2. Correct incorrect cyclic:
// This will usually fail upon loading:
//  "face 0 area does not match neighbour 2 by 0.0100005%"
//  " -- possible face ordering problem."
// - in polyMesh/boundary file:
//      - loosen matchTolerance of all cyclics to get case to load
//      - or change patch type from 'cyclic' to 'patch'
//        and regenerate cyclic as above
matchTolerance 0.001;
// Do a synchronisation of coupled points after creation of any patches.
// Note: this does not work with points that are on multiple coupled patches
//       with transformations (i.e. cyclics).
pointSync true;
// Optional: Write cyclic matches into .obj format; defaults to false.
//writeCyclicMatch  false;
// Patches to create.
patches
        // Name of new patch
        name inlet;
        // Dictionary to construct new patch from
       patchInfo
            type cyclicAMI;
            transform   translational;
            neighbourPatch outlet;
            separation     (-8.743006318923108e-15 0.8999999999999797 -1.315614284180811e-14);
        // How to construct: either from 'patches' or 'set'
        constructFrom patches;
        // If constructFrom = patches : names of patches. Wildcards allowed.
       patches (Inlet);
        // If constructFrom = set : name of faceSet
        set f0;
       name outlet;
      patchInfo
           type cyclicAMI;
           neighbourPatch inlet;
           separation      (8.743006318923108e-15 -0.8999999999999797 1.315614284180811e-14);
      patches (Outlet);
       set f0;
       name left;
       patchInfo
      	type cyclicAMI;
      	neighbourPatch right;
      	separation      (4.024558464266192e-15 -8.43769498715119e-15 0.4499999999999016);
       patches    (Left);
      set f0;
      name right;
      patchInfo
       type cyclicAMI;
       neighbourPatch left;
       separation  (-4.024558464266192e-15 8.43769498715119e-15 -0.4499999999999016);
      patches    (Right);
      set f0;
after I run the command "createPatch -overwrite"
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
7
    Top
        type            wall;
        inGroups        List<word> 1(wall);
        nFaces          16384;
        startFace       6569344;
    Ridges
        type            wall;
        nFaces          8192;
        startFace       6585728;
    Wall_below
        type            wall;
        nFaces          36864;
        startFace       6593920;
    inlet
        type            cyclicAMI;
        inGroups        List<word> 1(cyclicAMI);
        nFaces          17280;
        startFace       6630784;
        matchTolerance  0.0001;
        transformType   translational;
        separation      (-8.743006318923108e-18 0.0008999999999999797 -1.315614284180811e-17);
        method          faceAreaWeightAMI;
    outlet
        type            cyclicAMI;
        nFaces          17280;
        startFace       6648064;
        separation      (8.743006318923108e-18 -0.0008999999999999797 1.315614284180811e-17);
    left
        type            cyclicAMI;
        nFaces          18176;
        startFace       6665344;
        separation      (4.024558464266192e-18 -8.43769498715119e-18 0.0004499999999999016);
    right
        type            cyclicAMI;
        nFaces          18176;
        startFace       6683520;
        separation      (-4.024558464266192e-18 8.43769498715119e-18 -0.0004499999999999016);
I am trying to run on the Openfoam v8.0 that it is well working. But when I run it on the Openfoam extent 4.0 then I get the error as the above code.
So How to fix it for this issue in Openfoam extent 4.0 ?
Thank you for your help!
ht2017 is offline   Reply With Quote
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 14:26
Segmentation fault when using reactingFOAM for Fluids Tommy Floessner OpenFOAM Running, Solving & CFD 4 April 22, 2018 12:30
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 13:38
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 12:50
