January 10, 2022, 11:53 |
Problem with time step in Sandia flame d
Amirreza Niazmehr
Rep Power: 7 |
Hi guys
Actually I'm using SandiaD_LTS test case, but the time unite which OpenFOAM is using does not make sense to me at all. Is the unite of time in second? By the way, where can we define simulation time step? In chemistryProperties we can define our initial timestep, but is it constant? Because in the default setting of controlDict, 'end time' is set to 1500, but this time for combustion (injection) is not a reasonable value ! In combustion the time is ususallly in millisecond scale. Do you have probably any Idea about time units in Openfoam, specially by using this start time and end time and also Delta T. Where can I also change courant number? In attachment you can also find the picture of the ControlDict.orig file. Thanks alot in advance |
Convergence problem of OF | WUYing | OpenFOAM Running, Solving & CFD | 2 | September 20, 2021 10:09 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
Stuck in a Rut- interDyMFoam! | xoitx | OpenFOAM Running, Solving & CFD | 14 | March 25, 2016 07:09 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
