March 9, 2020, 09:50 |
chemkinToFoam not reading transport files
Daniel Thomas
Rep Power: 6 |
I am trying to convert mechanisms from Chemkin format for use in OpenFoam, but have not had any success getting the chemkinToFoam utility to work. I consistently get this error message with the transport file:
--> FOAM FATAL IO ERROR: "ill defined primitiveEntry starting at keyword '!' on line 1 and ending at line 1" Details: OpenFoam7 running on Ubuntu 18.04 via Windows subsystem for linux (WSL) |
March 10, 2020, 15:58 |
chemkinToFoam in use?
Daniel Thomas
Rep Power: 6 |
I'm new to OpenFOAM, so would also be interested to hear if anyone uses this chemkinToFoam utility. Is it something that is functional, or a relic from previous versions?
March 11, 2020, 05:00 |
Franco Marra
Rep Power: 17 |
Dear Daniel,
it should work, but in my experience the chemkin file has to be very compliant with the formatting rules of chemkin. Actually this is not the case for several mechanisms you can find in several websites. The chemkin program itself is able to recognize correctly several extensions and not perfectly conforming formats to chemkin rules. Best regards, Franco |
March 11, 2020, 08:37 |
Daniel Thomas
Rep Power: 6 |
Dear Franco,
Thank you for the note. I have noticed the inconsistency with Chemkin input files that you mention when I've converted them to Cantera cti format. But in that case, the error messages point me to the formatting problem; with chemkinToFoam, I get the same un-informative error no matter which input file set I use -- even the ones that are seemingly right on the Chemkin standard. Daniel |
March 12, 2020, 22:04 |
Rep Power: 14 |
If it is indeed a problem with the transport files it is likely not a problem with the mech file; check out the chemFoam tutorials. You'll notice that they use a file named something like transportProperties that is in Foam format -- not chemkin format. As noted previously, openfoam can also be quite picky about the format of the mech file (chemkinToFoam will also read the mech thermo just fine, possibly with just minor edits).
Caelan |
March 17, 2020, 08:33 |
Daniel Thomas
Rep Power: 6 |
Caelan - Thank you for the note! I had been using the chemkin format transport file, as indicated by the chemkinToFoam help:
Usage: chemkinToFoam [OPTIONS] <CHEMKIN file> <CHEMKIN thermodynamics file> <CHEMKIN transport file> <OpenFOAM chemistry file> <OpenFOAM thermodynamics file> It looks like the transportProperties file in the chemFoam tutorials is just a dud, with Sutherland As and Ts parameters set to zero. I'm modeling laminar diffusion flames, so the transport properties are important, and I'll need to figure out how to input that -- preferably from the chemkin file. So any suggestions on the best approach for that would be much appreciated. |
May 26, 2021, 16:43 |
Yan Zhang
Rep Power: 12 |
You may try my recently implemented reactingCanteraFoam: https://github.com/ZhangYanTJU/reactingCanteraFoam
https://openfoam.top |
April 29, 2022, 02:07 |
Ajith U K Nair
Rep Power: 4 |
Hello. If you were able to solve the issue kindly post the solution. I would relally appreciate it. I have the same error implementing sandeago mechanism for ethylene.
chemkintofoam, mechanism, pre-processing |
[General] Error while reading VTK files in Paraview | d_ray | ParaView | 12 | January 24, 2018 08:00 |
Reading data files in Matlab the Fortran way | faysaal | Main CFD Forum | 7 | October 25, 2015 09:56 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 10:46 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 20:51 |
