Proper wall boundary condition for rotating AND oscillating cylinder in a flow
Old   July 6, 2022, 21:20
Default Proper wall boundary condition for rotating AND oscillating cylinder in a flow
De Broglie
de_Broglie is on a distinguished road
Hi All,
I have a simple 2D cylinder with a prescribed motion of rotation around its center (constant rotational speed), AND oscillation in the vertical direction (sinusoidal motion).
If we were to have rotation only, we wouldn't need any mesh movement and rotatingWallVelocity boundary condition would work for the cylinder.
If we were to have oscillation only, we would need moving mesh with prescribed motion, and so would need movingWallVelocity.
What boundary condition should we use when we have both motions?
Other words, oscillation needs moving mesh, rotation doesn't, and so neither movingWallVelocity nor rotatingWallVelocity would work.
de_Broglie is offline   Reply With Quote
movingwallvelocity, openfoam, oscillatory motion, rotatingwallvelocity, rotational motion
How to implement time-varying boundary conditions in an enclosed cylinder Alejandro-FA OpenFOAM Pre-Processing 0 May 14, 2020 06:29
pimpleFoam - Flow across an oscillating cylinder simulation crashing iceman53y OpenFOAM Running, Solving & CFD 2 November 27, 2019 05:13
Boundary Condition - Conserve mass, oscillating tank K_Suth FLUENT 0 July 6, 2017 11:47
turbulent channel flow with spanwise oscillating velocity boundary condition arnaud6 OpenFOAM Running, Solving & CFD 1 August 5, 2013 14:18
Mass flow rate boundary condition for continuity equation for oscillating flow p07ip705 Main CFD Forum 0 February 28, 2013 01:33
