Boundary conditions for inlet and outlet of fluid flow in a tube
Old   September 30, 2022, 05:28
Default Boundary conditions for inlet and outlet of fluid flow in a tube
Giulia
letoppina is on a distinguished road
I am trying to simulate a heated tube (solid region) in which a fluid is flowing inside (fluid region). I am using openFoam version 6 and the chtmultiregionfoam solver.
The fluid enters the tube at the inlet with a certain initial temperature, flows through the tube, reaches the outlet of the tube, and comes back in a sinusoidal fashion. So it means that once the fluid enters the tube, it remains inside and it moves back and forth. It interacts with the tube walls (which are heated) so the fluid will heat up and increase its temperature. (please see the picture)
The fluid has a certain inlet temperature and inlet velocity but with time it should absorb the heat generated by the solid region.
What should be the boundary condition for the fluid (p, T, U, prg, etc.) at the inlet and outlet?
letoppina is offline   Reply With Quote
boundary condition, chtmultiregionfoam, inlet and outlet, water flow
Question about different kinds of Boundaries and Boundary Conditions granzer Main CFD Forum 17 April 12, 2022 17:27
Centrifugal fan j0hnny CFX 13 October 1, 2019 13:55
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 11:19
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
