Manual decomposition using setFields
Like Tree40Likes
  • 40 Post By RL-S
Old   September 28, 2017, 06:27
Default Manual decomposition using setFields
Lennart Steffen
RL-S is on a distinguished road
Hey there,
I found a couple of old threads about the manual option in decomposeParDict, and how to conveniently prepare the file for it with the setFields utility:
DecomposePar utility
Manually divide sub-domain for parallel computing
It was possible to piece the answer together from these threads, but it took me a couple of hours, so I wanted to share my solution here. There might be more elegant ways and I'm open to suggestions, but it works and it's fast enough.
First, I'll explain the problem, then I'll describe my solution.
The problem:
The manual option in the decomposeParDict file offers a lot of versatility, but is difficult to use, because you have to provide a file with a labelList the size of your mesh cell count. Each entry signifies the processor that cell is on. The exact file formatting is not completely trivial to find in the docs, but that's doable. However, actually creating that file manually doesn't really make sense, especially for larger meshes.
While the setFields utility provides a very convenient way of writing that list, its input- and output formatting is slightly different to the one for the needed file.
My solution:
Make sure your mesh is created and your system/decomposeParDict looks something like this:
|  \\    /   O peration     | Version:  4.x                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    note        "mesh decomposition control dictionary";
    object      decomposeParDict;
numberOfSubdomains  2;
method          scotch;
scotchCoeffs
manualCoeffs
    dataFile    "cellDist";
Then open a terminal in your case directory and get your current decomposition file by executing
decomposePar -cellDist
That will write a file called cellDist in 0/.
Now we need to write our desired decomposition into the system/setFieldsDict. Just as an example, it can be sth like this:
|  \\    /   O peration     | Version:  1.7.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      setFieldsDict;
defaultFieldValues ( volScalarFieldValue cellDist 0 );
regions
      boxToCell
           box ( 0.5 0 0 ) ( 1 0.5 1 ) ;
           fieldValues ( volScalarFieldValue cellDist 1);
      boxToCell
           box ( 0 0.5 0 ) ( 0.5 1 1 ) ;
           fieldValues ( volScalarFieldValue cellDist 2);
      boxToCell
           box ( 0.5 0.5 0 ) ( 1 1 1 ) ;
           fieldValues ( volScalarFieldValue cellDist 3);
For a cube with an edge length of 1, this would cut it into four regions of equal size. That's really just an example, and you'll know better what suits your case. In my case, I needed to put boundary patches on opposite sides of the mesh on the same processor, and that was easier with this method than with the others.
Now go back to your terminal and execute
setFields ; touch prepDecomp.py
This will rewrite your file cellDist in 0/ according to your desired decomposition. It also creates an empty file called prepDecomp.py (you may change the name if you want), which we open and paste the following into:
#read file
with open("0/cellDist", "r") as cdFile:
    lines = cdFile.readlines()
#replace and delete unwanted lines
lines[11] = lines[11].replace("volScalarField", "labelList")
lines[12] = lines[12].replace("0", "constant")
del lines[17:21]
bfline = 0
for i, line in enumerate(lines):
    if (line.find("boundaryField") != -1):
        bfline = i
        break
del lines[i:]
#write file
with open("constant/cellDist", "w") as cdFile:
    for line in lines:
        cdFile.write(line)
Now we execute that python script through the terminal with
python prepDecomp.py
This will modify the file according to the needed input format for the decomposePar utility.
Next, we set the keyword method in system/decomposeParDict to manual, and we're good to go.
Your workflow for designing your preferred decomposition may be this:
  1. Edit setFieldsDict
  2. Execute
    rm -r processor* ; setFields ; python prepDecomp.py ; decomposePar
  3. Check the cell and boundary face counts and see whether it looks good. If yes, you may run your solver, if not, start over from 1.
I needed this, because I used a codedFixedValue BC that accessed a patch on another processor core. This way, I could just place them on the same core, at least as a stopgap solution.
Hope this might help someone.
Lennart
Edit: I didn't try this method with binary format, so if you run into problems, make sure the writeFormat keyword in system/controlDict is set to ascii for the whole process. That way you can at least see what's happening.
RL-S is offline   Reply With Quote
Old   February 7, 2018, 06:30
Timm Feigel
Timm Feigel is on a distinguished road
Works perfectly, thank you!
Timm Feigel is offline   Reply With Quote
Old   March 20, 2018, 02:18
Default Works Perfectly.
b_k
b_k is on a distinguished road
Thanks for sharing. Works perfectly.
b_k is offline   Reply With Quote
Old   August 25, 2018, 00:18
Default Perfect!
Eldrael is on a distinguished road
Works great!
Thanks for the help!
Eldrael is offline   Reply With Quote
Old   October 2, 2018, 09:04
Smile
Mateusz
maTTe778 is on a distinguished road
It works great. Many thanks !
maTTe778 is offline   Reply With Quote
Old   August 24, 2020, 10:43
Patti Michelle Sheaffer
pattim is on a distinguished road
Thanks for taking the time to share a solution!!
pattim is offline   Reply With Quote
Old   August 12, 2021, 06:24
Giovanni Luddeni
gionni is on a distinguished road
I didn't really follow the steps, i just used funkySetFields, but I couldn't find in any tutorial an example of the file to put in the constant folder, very helpful, thank you!
Just changing a few lines I got a nice script to decompose a multiregion case in a proper way
gionni is offline   Reply With Quote
Old   May 10, 2023, 20:59
Desh
dasith0001 is on a distinguished road
Hi Giovsnni,
Since you have figure out a proper way of manual decompose of a multiRegion, would you mind sharing the details, particular to the multiRegion ?
Thank you
Dasith
dasith0001 is offline   Reply With Quote
Old   July 3, 2023, 08:51
Krapf is on a distinguished road
I have adapted the line numbers to OpenFOAM v2212:
#read file
lines[12] = lines[12].replace("volScalarField", "labelList")
lines[13] = lines[13].replace("0", "constant")
del lines[18:21]
bfline = 0
        bfline = i
        break
del lines[i:]
#write file
    for line in lines:
         cdFile.write(line)
It is also possible to skip the first decomosePar by manually creating a dummy file for 0/cellDist:
|  \\    /   O peration     | Version:  v2212                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      cellDist;
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0;
boundaryField
        type    fixedValue;
        value   uniform 0;
Krapf is offline   Reply With Quote
codedfixedvalue, decomposepar, manual decomposition, python, setfields
Looking for an example/help with manual decomposition KTG OpenFOAM Pre-Processing 2 March 27, 2017 23:06
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
Manual Decomposition Method smraniaki OpenFOAM Pre-Processing 3 November 24, 2013 16:53
Manual decomposition of domain pss OpenFOAM Pre-Processing 0 April 26, 2012 01:33
Description file for manual decomposition A.Devesa OpenFOAM Running, Solving & CFD 2 July 4, 2011 08:09
