Heat source for ignition - reactingFoam
Old   July 25, 2023, 07:43
Default Heat source for ignition - reactingFoam
Moomin is on a distinguished road
I am a beginner in openFOAM and have been using this forum for some time to learn how to model combustion processes.
In my current project I have a three dimensional burner geometry with multiple air and fuel inlets (geometry has already been used for studies in Fluent). Consequently, the flame to be simulated is not premixed.
I managed to choose the boundary conditions and initial conditions properly, so that the pure flow simulation via reactingFoam works well.
However, my problem is the ignition of the air-fuel mixture. If I, analogous to the e.g. DLR-A Flame Tutorial, provide a high temperature volume via "setFields", which is activated after the development of the flow, no ignition occurs. Furthermore, it seems that in this case the entire simulation aborts.
For alternative ignition options I have searched this forum. Some good approaches were suggested, which I could not implement successfully so far:
  • The creation of a "cellSet", which is set to a high temperature via "fvControl" does not work. The "cellSet" is not visible in ParaView and therefore the temperature is not increased (I have checked via "cellZones" that the dimensions of the "cellSet" are correct).
  • Furthermore, I tried to define a "cellSet" as Heat source via the option "fvModels" (which replaced "fvOptions" from OF9 on as far as I know). But I also cannot see any increased temperature as a reult.
Is there any other way to ignite the air-fuel mixture? Are there any compatibility problems between "fvOptions" or "fvModels" and reactingFoam?
My used version is OF10 and the reaction mechanism is GRI3.0 (aud the DLR-A Flame Tutorial).
Many thanks for your help in advance.
Kind Regards
Moomin is offline   Reply With Quote
cellset, flame, fvmodel, ignition, reactingfoam
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 08:06
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 16:18
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
