How to define the values of k and epsilon in pimplefoam? |
April 18, 2024, 09:42 |
mo magd
Rep Power: 2 |
Hi all,
I'm new to turbuluence modeling and not sure how I should specify the values of k and epsilon in zero directory for the problem I'm trying to simulate. I'm trying to simulate a mixing process in a micromixer device but when i put the values of k and epsilon close to zero ( since I initilize the flow field with zero velocity) the simulation crashes but when i put the values equal to 1, it converges. However, when I increase the value of velocity for analyzing higher Reynolds number, my simulation crashes again even with k and epsilon = 1. So I was wondering how I should define these values and whether I need to change them case by case if I change the velocity magnitude? Thanks so much for your help. |
k-epsilon model, pimple. openfoam, turbule modelling |
How can values of profile(k, epsilon) not change? | minque | FLUENT | 4 | January 22, 2020 14:14 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 16 | March 4, 2017 08:30 |
Help on values of k and epsilon for the k-epsilon equation | gauravshenoy | OpenFOAM Pre-Processing | 0 | July 31, 2014 08:02 |
Jump in epsilon values near the wall : low re k-epsilon model | malaboss | OpenFOAM Verification & Validation | 1 | February 1, 2013 16:36 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 20:21 |
