April 29, 2024, 10:06 |
fvOption configuration
Luca Fanchini
Rep Power: 2 |
Hi, Is it possible to give an Excel file as input to fvOption, where in one column there's the time and in another column there's the trend of the heat generation that I want to assign to my cellZone?
Thank you in advance to whoever responds. |
May 17, 2024, 05:46 |
Luca Fanchini
Rep Power: 2 |
Or is it possible in a different way?
May 17, 2024, 08:56 |
Yann
Rep Power: 26 |
if the variable is a type function1, you should be able to use a table or a csv file as an input. Whether it is a function1 or not depends on which OpenFOAM version and fvOptions source you are using. |
type limitTemperature problem | AdamRM | OpenFOAM Running, Solving & CFD | 6 | November 16, 2023 05:55 |
AMD Genoa best configuration for 128 cores Fluent/Mechanical licenses | chefbouza74 | Hardware | 10 | February 22, 2023 11:45 |
CFD workstation configuration calling for help 2 | Freewill1 | Hardware | 6 | July 8, 2020 21:17 |
[OpenFOAM.org] Cannot open configuration file mpicc-wrapper-data.txt mpicc: Not found | wenjuny | OpenFOAM Installation | 0 | November 25, 2019 09:01 |
Multiple Configuration Simulation | Tristan | CFX | 0 | November 13, 2009 23:01 |
