Tensor operation scale
Old   August 22, 2007, 11:49
Default In programmer's guide: c_i =
Maka Mohu
maka is on a distinguished road
c_i = scale(a, b) = (a1*b1, a2*b2, a3*b3)
I'm looking for a similar operation but with division operators.
scalediv(a, b) = (a1/b1, a2/b2, a3/b3). Is there a function to do that? or I have to write a one? I intend to use it on 2 volVectorFields Thanks.
Best regards,
Maka
maka is offline   Reply With Quote
Old   August 22, 2007, 11:57
Default I needed this in my developmen
Hrvoje Jasak
I needed this in my development stuff a while back and it's been added to my development version. It's called invScale.
I would recommend thinking carefully if you really need it or not. If you do, you can grep and search because for proper functionality it needs to be added in 4-5 places.
Good luck,
Hrv
Hrvoje Jasak
Old   August 22, 2007, 14:21
Default I do not know how complicated
paka is on a distinguished road
I do not know how complicated is your case, but can't you simply make d_i = 1/b_i and then a_i * d_i ?
paka is offline   Reply With Quote
Old   August 23, 2007, 05:41
Default Thanks Hrv, I will try it. @
Maka Mohu
@Krystian: the operation of scalar division is defined as tensor/scalar but not the opposite. As a result 1/tensor will give a compilation error.
Best regards,
Maka.
Old   August 23, 2007, 06:06
Default Which is exactly what it shoul
Gavin Tabor
grtabor is on a distinguished road
Which is exactly what it should do. What do you mean by 1/tensor? The operation is not mathematically defined. You could ask for the inverse of the tensor, of course, but is that what you mean?
For that matter, scaling one vector by another component-wise probably is mathematically a bit dodgy as well. If you are looking for a transformation of the vector by different amounts in each direction, once again this would be a tensor operation.
Gavin
grtabor is offline   Reply With Quote
Old   August 23, 2007, 08:52
Default The operation of devision is n
Maka Mohu
The operation of devision is not defined for vector (example of a tensor) because it only has a meaning when they are parallel. But here what I'm after is not an legitimate operation on vector or tensor. I need a scaling FUNCTION, that can take on vector field and scale it by another vector field (element by element scalar division). Assume you have two terms in an equation and you explicitly want to see how they wait relative to each other during run time. Then you will not Hrv's invScale function. That was exactly my situation. Thanks Gavin and Krystian for your comments. Please feel free to criticize the need that I explained. At the moment, I'm recompiling after I added Hrv's function. Thanks for your help.
Best regards,
Maka.
Old   November 11, 2008, 12:57
Default If we have an equation: s*T1=
Maka Mohu
s*T1=T2; where s is unknown scalar; T1 and T2 is two tensors; How can we calculate s by well defined mathematical operation?
s=T2/T1; is not mathematically defined. Thanks.
Old   November 11, 2008, 13:07
Default I think it should be: s*T1*
Maka Mohu
s*T1*inv(T1)= s*I=T2*inv(T1);
Then we know X=s*I;
s=sqrt(mag(X)/n); where n is the number of diagonal elements of the tensor I;
is that correct? Thanks.
Old   November 20, 2008, 07:43
Default I think it is: s=tr(T2 & in
Maka Mohu
I think it is:
s=tr(T2 & inv(T1))/3;
Old   September 11, 2012, 02:36
Maosong Cheng
mscheng is on a distinguished road
where can I find invScale function?
mscheng is offline   Reply With Quote
Old   October 10, 2013, 20:27
Dongyue Li
sharonyue is on a distinguished road
Anyone knows where can I find this scale function's header?
sharonyue is offline   Reply With Quote
Dimension problem with operation scale booz OpenFOAM Pre-Processing 0 October 10, 2008 03:57
Large Scale Model:Small scale computer gull COMSOL 0 March 5, 2007 06:37
scale or full scale justin FLUENT 1 August 4, 2006 22:00
relation b/n Kolomogorov scale and Taylor scale hanman Main CFD Forum 0 February 28, 2006 04:16
Convert color-scale pictures to gray-scale ones XC FLUENT 4 March 29, 2005 18:55
