September 4, 2008, 03:50 |
hi guys,
i am getti
hi guys,
i am getting this problem often for simple Foam as well as turbFoam. the message is Time = 243 DILUPBiCG: Solving for Ux, Initial residual = 0.0921126, Final residual = 0.00118057, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.0227887, Final residual = 0.000450739, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.0322668, Final residual = 0.000457125, No Iterations 1 #0 Foam::error::printStack(Foam:stream&) in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM. so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM. so" #2 ?? in "/lib64/libc.so.6" #3 Foam::DICPreconditioner::calcReciprocalD(Foam::Fie ld<double>&, Foam::lduMatrix const&) in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM. so" #4 Foam::DICPreconditioner::DICPreconditioner(Foam::l duMatrix::solver const&, Foam::Istream&) in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM. so" #5 Foam::lduMatrix::preconditioner::addsymMatrixConst ructorToTable<foam::dicprecond itioner>::New(Foam::lduMatrix::solver const&, Foam::Istream&) in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM. so" #6 Foam::lduMatrix::preconditioner::New(Foam::lduMatr ix::solver const&, Foam::Istream&) in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM. so" #7 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM. so" #8 Foam::fvMatrix<double>::solve(Foam::Istream&) in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVol ume.so" #9 main in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/applications/bin/linux64GccDPOpt /simpleFoam" #10 __libc_start_main in "/lib64/libc.so.6" #11 Foam::regIOobject::readIfModified() in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/applications/bin/linux64GccDPOpt /simpleFoam" Fließkommafehler junkers-selv_si:~/OpenFOAM1.5/selv_si-1.5/run/tutorials/simpleFoam/kabine_withp/ kabine_p_KEpsilon 22:45 > control application simpleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 1000; deltaT 1; writeControl timeStep; writeInterval 50; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression uncompressed; timeFormat general; timePrecision 6; runTimeModifiable yes; please help me to rectify this problem. with regards, sivakumar |
September 4, 2008, 13:48 |
Simply, your simulation diverg
Francesco Del Citto
Rep Power: 18 |
Simply, your simulation diverges, I'm afraid...
September 5, 2008, 03:06 |
hello,
how can i solv
hello,
how can i solve this problem? with regards, sivakumar |
September 5, 2008, 13:09 |
You should play with your nume
Francesco Del Citto
Rep Power: 18 |
You should play with your numerical schemes and/or improve the quality of your mesh.
Try to post here the output of checkMesh and your fvSchemes and fvSolution files. Maybe someone can suggest you some improvement... |
September 6, 2008, 11:01 |
Try manipulating internal Fiel
Ameya Durve
Try manipulating internal Field values. My experience with OpenFOAM tells me that the codes are very sensitive to initial values.
What is phi in simpleFoam | ehsan_vaghefi | OpenFOAM Running, Solving & CFD | 7 | September 29, 2013 11:00 |
SimpleFoam Convergence problem | skabilan | OpenFOAM Running, Solving & CFD | 6 | May 31, 2013 03:21 |
Convergence problem using simpleFoam steady state | vvqf | OpenFOAM Running, Solving & CFD | 12 | May 18, 2011 07:51 |
Help Troubleshooting simpleFoam problem on Harpoon made mesh | lhcamilo | OpenFOAM Bugs | 1 | February 18, 2009 07:11 |
Using simpleFoam with water | nico765 | OpenFOAM Running, Solving & CFD | 7 | October 23, 2007 05:39 |
