FoamX error shared object file not found
Old   June 21, 2008, 01:26
Default While I run FoamX, following m
M M Karim
mdmk is on a distinguished road
While I run FoamX, following message is dispalyed:
Starting NameServer with inet:karim.mashud:1234....
nsd:error while loading shared libraries:libssl.so.0.9.8:
cannot open shared object file: No such file or directory
Can anyone tell what the problem is and what I should do to remove this error.
With thanks..
MMK
mdmk is offline   Reply With Quote
Old   June 21, 2008, 15:35
Default This is not an error - the lib
musaddeque hossein
musahossein is on a distinguished road
This is not an error - the libssl.so.0.9.8 is in your system library, but named differently. You need to locate it and provide a "soft" link to the actual file. You may not have libssl.so.0.9.8 but may have libssl.so.0 or something like that. Once you do a soft link, you should be ok.
musahossein is offline   Reply With Quote
Old   June 22, 2008, 05:19
Default hi! i think you should just i
hamdi
hamcer is on a distinguished road
hi!
i think you should just install libsl (which y can find it in a system pakage ) and it'll be ok,
good luck.
hamcer is offline   Reply With Quote
Junction Box Routine Shared Object Library sam CFX 0 March 3, 2008 12:52
Shared Libraries for FOAMX mardit OpenFOAM Installation 4 June 1, 2007 11:55
file not found - formula.obj xhliu1 Siemens 0 March 29, 2007 05:24
problem with reading the .dat file,error object:#f Paulina FLUENT 6 November 7, 2006 15:49
Error when loading a shared library rid FLUENT 4 May 29, 2006 14:51
