Java error while starting FoamX
Old   March 6, 2007, 16:52
Default I have installed OpenFOAM 1.3
Ery Djunaedy
erydj is on a distinguished road
I have installed OpenFOAM 1.3 on an AMD64 ubuntu system today.
The installation is ok, I can run the first tutorial without problem. But when I try to start FoamX I receive this error:
****START ERROR*********
Exec : FoamXHostBrowser
Date : Mar 06 2007
Time : 14:53:42
Host : erydj-desktop
PID : 11322
Root :
Case :
Nprocs : 1
HostBrowser running.....
Using jar /home/erydj/OpenFOAM/OpenFOAM-1.3/applications/utilities/preProcessing/FoamX/lib /FoamX.jar
Using jar /home/erydj/OpenFOAM/OpenFOAM-1.3/applications/utilities/preProcessing/FoamX/lib /jlfgr-1_0.jar
/home/erydj/OpenFOAM/OpenFOAM-1.3/bin/FoamX: 243: /home/erydj/OpenFOAM/linuxAMD64/j2sdk1.4.2_05/bin/java: not found
Killed
runFoamXHB : cleanup
runFoamXHB: Killing name server nsd(pid 11318).
****END ERROR***********
It seems that the java executable cannot be found. I have checked that the file does exist in the specified directory.
I found similar problem on OpenFOAM 1.2:
http://www.cfd-online.com/OpenFOAM_D...tml?1151539351
The problem on that thread was missing app.class from lib/FoamX.jar. However, I could not even execute "jar lib/FoamX.jar" because it will have the same error message that "jar" file cannot be found. Furthermore, I believe that the missing app.class has been corrected in 1.3.
Any suggestion where should I move from this point?
Thanks,
Ery
erydj is offline   Reply With Quote
Old   May 3, 2007, 18:12
Default having the same problem with 1
ziad is on a distinguished road
having the same problem with 1.4 on kubuntu feisty faun (fresh install with no previous OF versions).
there is a App.class in:
OpenFOAM-1.4/applications/utilities/preProcessing/FoamX/lib/FoamX.jar
Can the case difference cause the error?
ziad is offline   Reply With Quote
Old   May 4, 2007, 08:53
Default I had a similar problem with F
Dominique Turmel
doum is on a distinguished road
I had a similar problem with FoamX on Fedora Core 6. I had to set SELinux secutiry to disabled... In a first time, it was set to "Strict" and that was the problem... Hope this can help!
doum is offline   Reply With Quote
Starting FoamX error jaswi OpenFOAM Installation 15 February 7, 2012 14:53
FoamX and Java Issues olih OpenFOAM Installation 5 March 30, 2008 17:22
FoamX starting on Fedora 8 x86_64 and i386 Error nsd ORBIIOPAddr %24myIOP ior %24FOAMX_CONFIGnsref %2360 devnull rationaalinen OpenFOAM Pre-Processing 6 December 2, 2007 11:40
FoamX not starting Javarelated error agrahn OpenFOAM Pre-Processing 5 October 20, 2007 05:33
Java error while starting FoamX cfdengineering OpenFOAM Pre-Processing 16 June 28, 2006 20:02
