wall functions for RAS models
Old   April 7, 2010, 07:43
Default wall functions for RAS models
Epf
Epf is on a distinguished road
Hi everyone,
is there a way to turn off the wall functions for the turbulent quantities in OpenFOAM 1.6? I'm a bit confused about this. I know that the RAS-models should be used with wall functions. But i want to compare the result with and without them to see the difference. Together with refining of my mesh.
Thank you in advance, Eric
Epf is offline   Reply With Quote
Old   April 8, 2010, 03:48
Michael
farbfilm is on a distinguished road
maybe you can use "calculated" instead of (for example) "nutWallFunction" in the nut-file of your 0-directory!
But I'm not sure...
farbfilm is offline   Reply With Quote
Old   April 8, 2010, 04:00
Michael
I tested it in the pitzDaily-tutorial and it worked (but I didn't checked the results)!
I think you also have to change the boundary conditions for k and epsilon in 0-directory! I used zeroGradient instead of kqRWallFunction and epsilonWallFunction!
Old   April 8, 2010, 11:14
cboss is on a distinguished road
you can use several provided RANS turbulence models without (log-law) wall functions. At least on can use the k-omega and k-omega-SST models. There is also a modified k-epsilon model for that purpose, the launder sharma KE.
If you are using the k-omega-SST model, I can tell you my setup for low-Re wall-treatment.
For boundary conditions at the wall, k=0, mut=0, omega=omegaWallFunction.
Note, that there is a new omegaWallFunction (very nice!) for low-Re wall-treatment. Therefore have a look at this thread.
http://www.cfd-online.com/Forums/ope...megasst-2.html
cboss is offline   Reply With Quote
Wall functions for near wall treatment : k - epsilon model fivos Main CFD Forum 4 April 27, 2011 07:44
abt near wall turbulence wall functions amv Main CFD Forum 0 May 12, 2003 03:38
When I use the wall functions....! maximus Main CFD Forum 7 January 20, 2003 09:35
the problem of the wall functions www_sun Phoenics 2 March 13, 2002 19:15
Wall functions or low-Re models? J. P. Main CFD Forum 7 July 9, 1998 11:11
