May 18, 2011, 11:11 |
Question about decomposePar
Ryan Danks
Hello Foamers,
I'm hoping someone here can help answer this question regarding how the decomposition process works in decomposePar. Basically, I want to know if I run decomposePar on the same geometry with the same settings, will the mesh always be broken up the exact same way. Or will points on "the the borderline" between two processors not be consistantly mapped to the same processor. I've done some basic testing with hierarchical decomp and comparing the processor's points file and they look to be the same. But I'm wondering if this is true in the general case? If you're wondering why I'm asking this, I'm running an exterior simulation from multiple wind directions where each direction is a separate case and I want to know if I can just copy field files between the different cases without reconstructing. I realize that mapFields would do this for me, but in my previous experience mapFields with parallel sources and destinations doesn't work quite right. Thanks! |
May 19, 2011, 02:23 |
#2 | |
Mark Olesen
Rep Power: 40 |
decomposePar -fields Even if this is not the whole solution, it might be a good approach for you. This link might be of interest too: http://olesenm.github.com/2009/11/17...ludeIfPresent/ |
May 20, 2011, 09:24 |
Ryan Danks
Thanks for the tip! It had never occurred to me to use symlinks before. That blog post was also very enlightening.
decomposepar, mesh |
Unanswered question | niklas | OpenFOAM | 2 | July 31, 2013 16:03 |
decomposePar: can use this decomposition method only for the whole mesh | aloeven | OpenFOAM Bugs | 0 | March 16, 2011 10:15 |
CHANNEL FLOW: a question and a request | Carlos | Main CFD Forum | 4 | August 23, 2002 05:55 |
question | K.L.Huang | Siemens | 1 | March 29, 2000 04:57 |
