OpenFoam help
Old   November 18, 2011, 08:00
Default OpenFoam help
Anirudh
Steinmann is on a distinguished road
Dear all ,
I am totally new with OpenFoam CFD tool box..But unfortunately I was assigned a small project . I tried to understand and do on my own. And am Struck here.
A simple geometry with three different velocities are given. And he specified simpleFoam steady state newtonian fluid.
Actually my problem is here after running simpleFoam.
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model SpalartAllmaras
--> FOAM FATAL IO ERROR:
Unknown patchField type nutSpalartAllmarasWallFunction for patch type wall
Valid patchField types are :
64
advective
atmBoundaryLayerInletEpsilon
buoyantPressure
calculated
codedFixedValue
cyclic
cyclicSlip
directMapped
directMappedField
directMappedFixedInternalValue
directMappedFixedPushedInternalValue
directionMixed
empty
epsilonWallFunction
fan
fanPressure
fixedFluxPressure
fixedGradient
fixedInternalValue
fixedPressureCompressibleDensity
fixedValue
freestream
freestreamPressure
inletOutlet
inletOutletTotalTemperature
kappatJayatillekeWallFunction
kqRWallFunction
mixed
nonuniformTransformCyclic
nutLowReWallFunction
nutTabulatedWallFunction
nutURoughWallFunction
nutUSpaldingWallFunction
nutUWallFunction
nutkRoughWallFunction
nutkWallFunction
omegaWallFunction
oscillatingFixedValue
outletInlet
outletMappedUniformInlet
partialSlip
processor
processorCyclic
rotatingTotalPressure
selfContainedDirectMapped
sliced
slip
symmetryPlane
syringePressure
timeVaryingMappedFixedValue
timeVaryingTotalPressure
timeVaryingUniformFixedValue
totalPressure
totalTemperature
turbulentHeatFluxTemperature
turbulentInlet
turbulentIntensityKineticEnergyInlet
turbulentMixingLengthDissipationRateInlet
turbulentMixingLengthFrequencyInlet
uniformDensityHydrostaticPressure
uniformFixedValue
waveTransmissive
wedge
zeroGradient
file: /home/anirudh/Desktop/Ani/0/nut::boundaryField::top from line 43 to line 44.
From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&)
in file /home/opencfd/OpenFOAM/OpenFOAM-2.0.1/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 135.
FOAM exiting
I couldn't get this error !!
Could somebody help me in running this !
Thanks a ton in advance
Steinmann is offline   Reply With Quote
Old   November 18, 2011, 08:07
Anirudh
Later I found that in RASmodel : spallartAllamars
Turbulence : on
I am looking for laminar one
SO changed like this RASmodel : laminar
Turbulence : on
Is this entry a correct one ?
By running this ..I get following errors
anirudh@anirudh:~/Desktop/Ani$ simpleFoam
| \\ / O peration | Version: 2.0.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
Build : 2.0.1-51f1de99a4bc
Exec : simpleFoam
Date : Nov 18 2011
Time : 14:01:11
Create time
Reading field p
Reading field U
Selecting RAS turbulence model laminar
SIMPLE: no convergence criteria found. Calculations will run for 4 steps.
Starting time loop
Time = 0.005
keyword div((nuEff*dev(T(grad(U))))) is undefined in dictionary "/home/anirudh/Desktop/Ani/system/fvSchemes::divSchemes"
file: /home/anirudh/Desktop/Ani/system/fvSchemes::divSchemes from line 31 to line 41.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 400.
FOAM exiting
Old   November 18, 2011, 08:16
Olivier
olivierG is on a distinguished road
hello,
In 0/nut, you define a non valid boundary condition "nutSpalartAllmarasWallFunction" which is not valid in 2.0
You may change to "nutUSpaldingWallFunction", but you didn't give much info about your case.
Take a look at the tutorial case :
tutorials/incompressible/simpleFoam/airFoil2D/
regards,
olivier
olivierG is offline   Reply With Quote
Old   November 18, 2011, 09:15
Anirudh
Dear Mr.Oliver,
Thank you for the reply....In my case, I should consider an Block Mesh like this with following boundary conditions. And I have to use simpleFoam(steady state one) in order to visualize the laminar flow. And the related graphs.The flow medium is considered as a newtonian one,for three different velocity cases v=1m/s, v=5m/s,v=10m/s
My Mesh is here :
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(2 0 0)
(10 0 0)
(10 2 0)
(10 4 0)
(2 4 0)
(0 4 0)
(0 2 0)
(2 2 0)
(2 0 1)
(10 0 1)
(10 2 1)
(10 4 1)
(2 4 1)
(0 4 1)
(0 2 1)
(2 2 1)
blocks
hex (0 1 2 7 8 9 10 15) (20 20 1) simpleGrading (1 1 1)
hex (6 7 4 5 14 15 12 13) (20 20 1) simpleGrading (1 1 1)
hex (7 2 3 4 15 10 11 12) (20 20 1) simpleGrading (1 1 1)
edges
patches
wall top
(5 13 12 4)
(4 12 11 3)
wall bottomAndSide
(1 9 8 0)
(7 15 14 6)
(8 15 7 0)
/*patch middle
(15 12 4 7)
patch inlet
(6 14 13 5)
patch outlet
(2 3 11 10)
(1 2 10 9)
empty frontAndBack
(6 5 4 7)
(7 4 3 2)
(0 7 2 1)
(8 9 10 15)
(15 10 11 12)
(14 15 12 13)
/* wall side
(8 15 7 0)
mergePatchPairs
RAS Properties :
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object RASProperties;
RASModel laminar;
turbulence on;
printCoeffs on;
Velocity for my first case v=1m/s
| \\ / A nd | Web: http://www.openfoam.org |
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (1 0 0);
boundaryField
inlet
type fixedValue;
value uniform (1 0 0);
top
type fixedValue;
value uniform (0 0 0);
outlet
type zeroGradient;
bottomAndSide
type fixedValue;
frontAndBack
type empty;
Control folder :
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application simpleFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 195;
deltaT 0.05;
writeControl timeStep;
writeInterval 20;
purgeWrite 1;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
Here I have copy - pasted the main files ,so that you can view my case.
But when I ran it couldn't solve...
Please let me know, what other changes would be possible...
Thank you in advance..
Old   November 18, 2011, 09:26
Olivier
For the error
You may add "div((nuEff*dev(T(grad(U))))) Gauss linear;" as a divSchemes in system/fvSchemes (take a look at tutorials ...)
and set turbulence off in Ras properties
regards,
olivier
Old   November 18, 2011, 09:33
Anirudh
Hello Mr.Oliver
I have made these changes.....
div((nuEff*dev(grad(U).T))) Gauss linear;
I ran it again....the following erros show up :
Create time
Reading field p
Reading field U
SIMPLE: no convergence criteria found. Calculations will run for 195 steps.
Starting time loop
Time = 0.05
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 8.60431e-07, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 8.90117e-07, No Iterations 2
GAMG: Solving for p, Initial residual = 1, Final residual = 0.0793663, No Iterations 4
time step continuity errors : sum local = 0.000476327, global = -1.21272e-19, cumulative = -1.21272e-19
ExecutionTime = 0.02 s ClockTime = 0 s
Time = 0.1
smoothSolver: Solving for Ux, Initial residual = 0.64159, Final residual = 0.0526798, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.619704, Final residual = 0.0470176, No Iterations 4
GAMG: Solving for p, Initial residual = 0.232835, Final residual = 0.0199787, No Iterations 3
time step continuity errors : sum local = 0.000714012, global = 9.7964e-19, cumulative = 8.58368e-19
Time = 0.15
smoothSolver: Solving for Ux, Initial residual = 0.188418, Final residual = 0.00856207, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.290141, Final residual = 0.0194256, No Iterations 4
--> FOAM FATAL ERROR:
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux : 100.795
Specified mass inflow : 2.40552
Specified mass outflow : 0
Adjustable mass outflow : 0
From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p
in file cfdTools/general/adjustPhi/adjustPhi.C at line 116.
FOAM exiting
Old   November 18, 2011, 09:45
Olivier
hello,
Try a more diffusive schem like gauss upwind, and initialise with potentialFoam or run with a lower velocity inlet, map the result and run again with bigger velocity.
regards,
olivier
Old   November 18, 2011, 14:02
Anirudh
Hallo Mr.Oliver ,
Finally I ran and I got some solution.But not sure with Post-processing figures(Velocity and pressure ).
If you could give me your E-Mail Id here
I can send my files to you.
Wherein you could look up for what I have done ...
Old   January 26, 2012, 10:44
wided
wiedangel is on a distinguished road
Originally Posted by Steinmann View Post
Dear all ,
Create time
Reading field p
Reading field U
64
advective
buoyantPressure
calculated
codedFixedValue
cyclic
cyclicSlip
directMapped
directMappedField
directionMixed
empty
epsilonWallFunction
fan
fanPressure
fixedFluxPressure
fixedGradient
fixedInternalValue
fixedValue
freestream
freestreamPressure
inletOutlet
kqRWallFunction
mixed
nutUWallFunction
nutkWallFunction
omegaWallFunction
outletInlet
partialSlip
processor
processorCyclic
sliced
slip
symmetryPlane
syringePressure
totalPressure
totalTemperature
turbulentInlet
uniformFixedValue
waveTransmissive
wedge
zeroGradient
FOAM exiting
are you using the 1.7.1 version? I had the same error which I solved by running under the version 2.0.1
wiedangel is offline   Reply With Quote
Old   February 2, 2012, 07:06
Default controlDict Error
Kanarya is on a distinguished road
Hi I am new in OpenFoam I am gettin this message
Can somebody help me?
Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
at twoPhaseEulerFoam.C:0
in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/twoPhaseEulerFoam"
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception
Thanks,
Recep
Kanarya is offline   Reply With Quote
Old   February 2, 2012, 07:10
  #11
Hi
Thanks,
Recep
Old   April 23, 2012, 12:15
musaddeque hossein
musahossein is on a distinguished road
Originally Posted by olivierG View Post
hello,
regards,
olivier
There are two versions of the adjustPhi on the internet:
http://foam.sourceforge.net/docs/cpp/a03897_source.html
the other one is:
ftp://ftp.ux.uis.no/uis/x/OpenFOAM/OpenFOAM-1.5.../adjustPhi.C
It appears the someone made corrections to the second one -- there is no hardcoded limit on the flux ratio. Can some one verify which one is better and how it can be implemented in the OpenFoam that I have?
Thanks.
musahossein is offline   Reply With Quote
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
