Massflow or average velocity boundary condition |
November 18, 2011, 09:55 |
Jan Willem Krijger
Rep Power: 16 |
Hello
I'm trying to simulate a pipeflow with 2 inflow boundary conditions and 1 outflow boundary condition using simpleFoam. I tried using a fixedValue boundary condition for the velocity at the outflow. But the simulation didn't converged and I got disturbances at the outflow. Which is expected because the flow is not uniform when it approaches the outflow boundary. I would like to define the velocity with zeroGradient at the inflow and the massflow or average velocity at the outflow. And the pressure with fixedValue at the inflow and zeroGradient at the outflow. How can I set the massflow or the average velocity at the outflow boundary? Any suggestions are appreciated!! |
November 18, 2011, 14:33 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
If I had to do such a thing I'd use groovyBC (basically using an expression for the value like "U*mfTarget/mfCurrent" - the two mfs being specified/calculated). Note that probably to get this stable you'll have to make it a bit more complicated: at least some kind of underrelaxation to avoid trouble during the startup-phase and you'll have to decide whether you allow backflow (because that would be accelerated by the scaling too). And of course there is the general problem of specifying the massflow at the outlet .... |
November 18, 2011, 19:20 |
Wouter van der Meer
Rep Power: 17 |
hello,
If you have two inlets and one outlet. I think the best thing to do is set the two inlet velocities (fixed value). Calculate the velocities from the ratio of flows through the inlet and the area of the inlets by hand and let simpleFoam calculate the outlet flow, what being an incompressible steady state should result in the asked for massflow. hope this helps Wouter |
November 21, 2011, 04:05 |
#4 | ||
Jan Willem Krijger
Rep Power: 16 |
Thank you both for your reply!
Ansys CFX does have a massflow boundary condition, could be a very nice addition to OPENFOAM! Quote:
Of course you could iterate between inlet velocities to end up with a similar pressure at both inlets. |
November 21, 2011, 12:50 |
Wouter van der Meer
Rep Power: 17 |
hello Jan Willem,
Maybe you can use my suggestion as a stable start for the simulation with groovyBC Best Wouter |
August 10, 2016, 05:16 |
Anton Kidess
Rep Power: 30 |
I think the fixedMean boundary condition works nicely for such a case.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
September 27, 2016, 15:09 |
Conservation of momentum
Rizvi
Rep Power: 9 |
Hello i am trying to solve the same problem in Ansys fluent , how do i check if momentum is conserved?
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
how can i give a boundary condition with pressure and velocity together | akhenathon | FLUENT | 6 | April 24, 2012 18:32 |
Robin boundary condition for the velocity | fumiya | OpenFOAM | 4 | June 17, 2011 02:58 |
vorticity boundary condition | bearcharge | Main CFD Forum | 0 | May 14, 2010 11:32 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
