New transformation option for utility: transformPoints
Like Tree3Likes
  • 3 Post By philippose
Old   January 13, 2012, 17:02
Default New transformation option for utility: transformPoints
Philippose Rajan
philippose will become famous soon enough
Hello and a Good Evening,
Today I had the need to rotate my mesh along a specific axis, which does not pass through the origin..... an arbitrary axis defined by two points.
As far as I can see, none of the rotation transforms in the mesh utility: "transformPoints" allows this kind of a rotation about an arbitrary line..... or am I wrong?
In order to achieve my requirement, I added on one more command line option to transformPoints: "-rotateAlongLine", which allows the mesh to be rotated along any arbitrary axis which does not need to pass through the origin, and is defined by:
1. A point which lies on the axis P1(x,y,z)
2. A direction vector which defines the axis, which would typically by P2 - P1 (where P2 is another point on the line which defines the axis)
3. The required rotation angle (in degrees)
Hence, the new command-line option looks like this:
transformPoints -rotateAboutLine "(0 -0.05 0) (1 1 0) 45"
The above command would rotate the mesh about an axis which passes through the point P1(0,-0.05,0) and has the direction vector (1,1,0) by an angle of 45 degrees.
The implementation of this option is as follows:
1. Translate the mesh such that the given point becomes the origin of the mesh....:
points -= pointOnLine;
2. Create a Rodrigues Rotation tensor using the specified direction vector and the rotation angle, and transform the points:
tensor T = RodriguesRotation(dirVector, rotationAngle);
points = transform(T, points);
3. Shift the mesh back to the original location:
points += pointOnLine;
It would be great if someone could add this to the Git repository of the OpenFOAM-1.6-ext project....? Unless this kind of operation is already possible (without having do it manually by using three calls to transformPoints i.e. :-)!)
If required, I can put up a zipped copy of the modified "transformPoints" utility.
Philippose
philippose is offline   Reply With Quote
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
