Pollution source at patch
Old   March 7, 2012, 02:52
Default Pollution source at patch
Anone
CFD_user_2012 is on a distinguished road
Hi
I would like to know how I can introduce a pollution source at an inlet patch. I am simulating vehicle pollutants at ground level. I think I need to first create a patch at the ground level for pollution.
How can I then specify the pollution Nitrogen dioxide, and emission rate ? I am using simpleFoam. Do I need to use another solver ?
thanks
CFD_user
CFD_user_2012 is offline   Reply With Quote
Old   August 31, 2012, 01:54
Robert
vainilreb is on a distinguished road
I'm working on a similar problem. I recommend you to use sprayFoam and simply add the species you want to trace as scalars. You can then define their concentrations at all boundaries. By e.g. defining your inlet patch beeing 100 mass percent nitrogen dioxide, it is possible to let NO2 flow into the domain.
Hope I was able to help.
Regards,
Rob
vainilreb is offline   Reply With Quote
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
