propeller tutorial using AMI in OF v2.1.0
Old   March 19, 2012, 17:07
Default propeller tutorial using AMI in OF v2.1.0
Kim Yusik
impecca is on a distinguished road
Dear foamers
I tried to set up a pitching airfoil case based on the propeller tutorial in OF v2.1.0. But a few points in the stationary part of domain follow the rotating domain. please see the red circle in the attached figure. Is there anyone who knows how to fix this?
The procedures which I followed are
- mesh generation in Gridgen (set 'insideSlider', 'outsideSlider' separately in BC sets)
- output as a fluent case file
- convert to into OF files using fluentMeshToFoam
- set up 'boudary' file for AMI (attachment, 'boundary.txt')
- set rotating cellzone by using 'setSet' -> cellSet insideZone new cylinderToCell (0.5 0 0) (0.5 0 0) 2.5 (see 'dynamicMeshDict.txt')
- setsToZone -noFlipMap
- run.
Regards
Yusik
impecca is offline   Reply With Quote
Old   March 20, 2012, 09:42
Kim Yusik
Problem is solved by using 'mergeMeshes' option.
I Generated 'insideSlider' and 'outsideSlider' separately and use 'mergeMeshes' option to merge these two mesh together.
Yusik
Old   April 10, 2012, 04:00
liping_he
liping_he is on a distinguished road
HI Yusik
I have the same question with you. My mesh has two domains, rotor and stator. AMI1 and AMI2 locate between the two domain. I have no idea about how to improe the .msh file to OF. I wish you can tell me the detailed process about mesh converting..thanks very much.
bestWishes
liping_he
liping_he is offline   Reply With Quote
Old   April 12, 2012, 02:41
kid
cfdkid
kid is on a distinguished road
@liping_he
Place your mesh in constant/triSurface
and type following command (cd .. cd ..)
mshToFoam
and then follow impecca's comments.
regards
CFDkid
kid is offline   Reply With Quote
Old   April 26, 2012, 04:14
liping_he
HI CFDkid
Thanks for your reply..
For now, I creat mesh using ICEMCDF, containing one domain. I have convert the mesh with fluent3DMeshToFoam. The issue is that how can i split the mesh into two domain (rotor and stator). another issue is how can i acquire AMI1 and AMI2 faces, and how to set rotor zones..
regards
liping
Old   April 27, 2012, 10:13
Kim Yusik
I am not very sure what your question means, but this slide may help you to understand how to specifying the AMI or GGI.
http://www.openfoamworkshop.org/6th_...sak_slides.pdf
see p.18.
Yusik
Old   May 9, 2016, 10:22
Aldias Bahatmaka
bmaldi is on a distinguished road
see p.18.
Yusik
Hello brother,
i couldn't open your slide, could you re-post your silde for me? thanks so much.
Best Regards,
Aldi.
bmaldi is offline   Reply With Quote
Propeller calculation toil CFX 15 May 22, 2017 04:06
propeller tutorial openfoam_user OpenFOAM Running, Solving & CFD 0 February 8, 2012 04:02
Modelling a propeller tomg STAR-CCM+ 4 April 28, 2011 17:22
Looking for tutorial for rotating propeller for Marine Applications naimishharpal STAR-CCM+ 0 February 7, 2011 22:12
a propeller 2 way fsi kantored CFX 9 April 11, 2007 14:51
