Problem with pow and volScalarField
Like Tree3Likes
  • 1 Post By Cyp
  • 1 Post By _Stefan_
  • 1 Post By Cyp
Old   May 7, 2012, 08:15
Default Problem with pow and volScalarField
_Stefan_ is on a distinguished road
I want to implement an new Order to Calculate the Viscosity nu.
Ostwald Waele Potential Function
tau = k * strain rate ^n
k and n are model Parameter and depend on rho
k=a*rho+b
n=c*rho+d
I got a, b, c, d from some experiments.
The equation for the rotation rheometer:
nu = tau / strain rate
What I have done:
//read strain rate
    tmp<volScalarField> sr(strainRate());
//Parameter
    dimensionedScalar ka_("ka_",dimensionSet(0,2,-1,0,0,0,0), 0.1202);
    dimensionedScalar kb_("kb_",dimensionSet(1,-1,-1,0,0,0,0), 24.912);
    dimensionedScalar na_("na_",dimensionSet(-1,3,0,0,0,0,0), 0.0005);
    dimensionedScalar nb_("nb_",dimensionSet(0,0,0,0,0,0,0), 0.2246);
//read ScalarFeldes rho_ps
    const tmp <volScalarField> & rhoCalc = U_.mesh().lookupObject<volScalarField>("rho_ps");
//calculation n and k
    volScalarField K = ka_ * rhoCalc + kb_;
    volScalarField N = na_ * rhoCalc + nb_;
//Calculation nu
    tmp <volScalarField> nu = K * Foam::pow(max(tone * sr(),VSMALL),N-1.);
tone is only a dimensioned scalar with 1[s] to make sr() dimensionless.
My Problem is that it did not compile.
If I change N in the pow function to an dimensioned scalar it works fine.
Is it possible that, Foam:ow (volScalarField, volScalarField) does not work?
Here the error massage:
/SimSoftware/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricScalarField.C:189: error: no matching function for call to ‘Foam::dimensioned<double>::dimensioned(const char [2], double, const Foam::dimensionSet&)’
/SimSoftware/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/dimensionedType.C:107: note: candidates are: Foam::dimensioned<Type>::dimensioned(const Foam::word&, const Foam::dimensionSet&, Foam::Istream&) [with Type = double]
/SimSoftware/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/dimensionedType.C:94: note: Foam::dimensioned<Type>::dimensioned(const Foam::word&, Foam::Istream&) [with Type = double]
/SimSoftware/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/dimensionedType.C:82: note: Foam::dimensioned<Type>::dimensioned(Foam::Istream &) [with Type = double]
/SimSoftware/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/dimensionedType.H:95: note: Foam::dimensioned<Type>::dimensioned(const Type&) [with Type = double]
/SimSoftware/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/dimensionedType.C:69: note: Foam::dimensioned<Type>::dimensioned(const Foam::word&, const Foam::dimensioned<Type>&) [with Type = double]
/SimSoftware/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/dimensionedType.C:55: note: Foam::dimensioned<Type>::dimensioned(const Foam::word&, const Foam::dimensionSet&, Type) [with Type = double]
/SimSoftware/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/dimensionedScalarFwd.H:42: note: Foam::dimensioned<double>::dimensioned(const Foam::dimensioned<double>&)
_Stefan_ is offline   Reply With Quote
Old   May 7, 2012, 09:33
Ben K
benk is on a distinguished road
I'm not sure about the answer to your question, but my first instinct would be to do this sort of operation within a forAll loop
benk is offline   Reply With Quote
Old   May 8, 2012, 05:06
Thank you,
I think it is not the best way but it works:
    Info << "calculate min strainrate" << endl;
    volScalarField sr1 = max(sr()*tone,VSMALL);//[-]
    Info << "forAll loop" << endl;
    forAll(sr1, cellI)
        N1[cellI] = Foam::pow(sr1[cellI],N[cellI]-1);
    tmp <volScalarField> nu =     K * N1;
Old   May 12, 2012, 13:09
Cyp
Cyprien
Cyp is on a distinguished road
Did you try N.value() instead of N within the exponent ?
Cyp is offline   Reply With Quote
Old   May 14, 2012, 07:30
Hi Cyp,
I tried it but there are the Error:
error: ‘struct Foam::volScalarField’ has no member named ‘value’
Old   May 14, 2012, 18:23
Cyp
Cyprien
Yes, sorry, .value is valid if N is a dimensionedScalar.
in your case, if you already have declared A, B and C as volScalarField, you can performed :
A.internalField() = Foam::pow(B.internalField(),C.internalField());
The operation does not include the operation upon BC.
Best,
Cyp
mm.abdollahzadeh likes this.
Old   May 15, 2012, 04:39
Thanks, Cyp that is what I need. I also need the calculation on the boundary so I added:
A.boundaryField() = Foam::pow(B.boundaryField(),C.boundaryField());
And it works fine!
Old   August 7, 2012, 07:38
mahdi abdollahzadeh
mm.abdollahzadeh is on a distinguished road
And it works fine!
Hi Stefan and Cyprien
I want to calculate the following relation.
A=min(0,c*B);
Which A and B are Volscalerfield and c diminesedscaler.
for the c i have used .value().
But I am receiving Eror when I have the B in the min function.
I have tried your suggestion but it does not work.
Could you help me?
Best
Mahdi
mm.abdollahzadeh is offline   Reply With Quote
Old   August 7, 2012, 07:45
Cyp
Cyprien
Have you tried without any .value() ?
Else, I suggest to do :
A = c*min(0,B);
Old   August 7, 2012, 07:49
mahdi abdollahzadeh
Yes I have tried, even for the follwing equations if I remove the .value() it is giving error.
A=min(0,c.value());
A.internalField()=min(0,c.value());
A.boundaryField()=min(0,c.value());
which is working because I removed the B. (but when I am adding the B it gives Error) .
Old   August 7, 2012, 07:50
Cyp
Cyprien
A=min(0,c.value());
see my edited post.
Old   August 7, 2012, 07:56
mahdi abdollahzadeh
Thanks again ,,, I think the problem is not related the "c" .
the error is :
error: no matching function for call to 'min(int, Foam::volScalarField&)'
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/label.H:213:1: note: candidates are: char Foam::min(char, char)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/label.H:214:1: note:                 short int Foam::min(short int, short int)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/label.H:215:1: note:                 int Foam::min(int, int)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/label.H:216:1: note:                 long int Foam::min(long int, long int)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/label.H:217:1: note:                 long long int Foam::min(long long int, long long int)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/label.H:219:1: note:                 unsigned char Foam::min(unsigned char, unsigned char)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/label.H:220:1: note:                 short unsigned int Foam::min(short unsigned int, short unsigned int)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/label.H:221:1: note:                 unsigned int Foam::min(unsigned int, unsigned int)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/label.H:222:1: note:                 long unsigned int Foam::min(long unsigned int, long unsigned int)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/label.H:223:1: note:                 long long unsigned int Foam::min(long long unsigned int, long long unsigned int)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/label.H:225:1: note:                 long int Foam::min(int, long int)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/label.H:226:1: note:                 long long int Foam::min(int, long long int)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/label.H:227:1: note:                 long long int Foam::min(long long int, int)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/doubleFloat.H:78:1: note:                 double Foam::min(double, double)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/doubleFloat.H:79:1: note:                 double Foam::min(double, float)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/doubleFloat.H:80:1: note:                 double Foam::min(float, double)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/doubleFloat.H:81:1: note:                 float Foam::min(float, float)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/doubleFloat.H:82:1: note:                 double Foam::min(double, int)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/doubleFloat.H:83:1: note:                 double Foam::min(int, double)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/doubleFloat.H:84:1: note:                 double Foam::min(double, long int)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/doubleFloat.H:85:1: note:                 double Foam::min(long int, double)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/doubleFloat.H:86:1: note:                 float Foam::min(float, int)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/doubleFloat.H:87:1: note:                 float Foam::min(int, float)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/doubleFloat.H:88:1: note:                 float Foam::min(float, long int)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/doubleFloat.H:89:1: note:                 float Foam::min(long int, float)
/home/mahdi/centFOAM//OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/dimensionSet.H:214:29: note:                 Foam::dimensionSet Foam::min(const Foam::dimensionSet&, const Foam::dimensionSet&)
Old   August 7, 2012, 08:04
Cyp
Cyprien
Althought it is not very elegant, the following snippet should works:
    forAll(A, cellI)
       A[cellI] = min(0,c.value()*B[cellI]);
Old   August 7, 2012, 08:05
mahdi abdollahzadeh
thanks Cyprein, it works
Old   August 7, 2012, 11:04
mahdi abdollahzadeh
A=min(0,c.value());
Dear Cyprein
I have done it with internalfield. the problem was to replace 0 with scalar(0) but there is one problem.
A.dimensionedInternalField()=min(scalar(0),B.dimen sionedInternalField()); A.boundaryField()=min(scalar(0),B.boundaryField()) ;
the above equation are compiling. but when I am replacing the dimensionedInternalField() with InternalField() it gives the error.???? ( and there is no dimensionedboundaryField() ).
Old   April 14, 2019, 22:20
Jianrui Zeng
calf.Z is on a distinguished road
If want to find the minimum of fMu, 1.0 and scalar(0.5)+0.0025*this->Rt() where fMu and Rt() are tmp<volScalarField>.
fMu(const volScalarField& Rt)
tmp<volScalarField> Ry(sqrt(k_)*y_/this->nu());
return sqr(scalar(1) - exp(-0.0165*Ry))*(scalar(1) + 20.5/(Rt + SMALL));
Rt()
return sqr(k_)/(this->nu()*epsilon_);
How should I do it? Thank you.
calf.Z is offline   Reply With Quote
if statement for volScalarField AnjaMiehe OpenFOAM Programming & Development 2 April 24, 2012 07:01
