MRFZone.C compiling
Old   June 29, 2012, 05:30
Default MRFZone.C compiling
Michal
majkl is on a distinguished road
I've changed the file MRFZone.C and I would like to compile the edited file.
~/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/cfdTools/general/MRF
The make files and options are located several directories up:
So I compile in this directory in this way:
wmake all
It compiles all dependent file in the finiteVolume, but my question is: Is it some easier way?(only compile the MRFZone.C)
Thanks.
Michal
majkl is offline   Reply With Quote
Old   July 10, 2012, 06:00
Tomislav Maric
tomislav_maric is on a distinguished road
You should write your own code in libraries/applications that are separate from the main code tree.
The usual way to do this is as follows:
Copy the .C and .H file into your own directory.
Rename the files : myMRFzone.C, myMRFzone.C (think of better names )
Rename the classes: use an editor with automatic name change executed on mutliple files
Create a Make/{files, options} in this directory (you can see how this looks like for libfiniteVolume.so, you need to only copy the lines from Make/files that pertain to myMRFzone, change the LIB to your name, and the options stay the same).
At the end, you have your own library compiled and ready to use. To use it, go into system/controlDict of a case you are running and put:
libs ("libMyNewLibrary.so");
at the top of the file.
tomislav_maric is offline   Reply With Quote
Old   July 10, 2012, 08:13
Michal
Dear Tomislav,
thanks. I'll try it.
Michal
Old   July 10, 2012, 08:15
Tomislav Maric
Originally Posted by majkl View Post
Dear Tomislav,
Michal
No prob, just ask if you run into trouble, if I catch some time, I'll help you compile it...
Problem with Compiling UDFs in Ansys Fluent 13 (lnx64) Ali.beh Fluent UDF and Scheme Programming 3 August 27, 2018 04:22
paraview 3.10.1 compiling error (1.6-ext) vkrastev OpenFOAM Installation 7 October 28, 2011 03:17
Help with KIVA4 source code compiling geothokar Main CFD Forum 0 September 3, 2010 05:40
Dissimilarity in compiling new BC in 32bit OpenSuSE 103 versus 64bit CentOS 50 versus 64bit SLED 100 sponiar OpenFOAM Running, Solving & CFD 3 February 26, 2008 06:31
Discussing UDF and C++ Compiling Big Stone FLUENT 9 April 12, 2004 15:07
