localBlended
Like Tree10Likes
  • 9 Post By bjnieuwboer
  • 1 Post By bjnieuwboer
Old   August 10, 2012, 11:04
Default localBlended
Julien
Djub is on a distinguished road
Hi !
I would appreciate some info about the use of localBlended.
I know the post Using the localBlended scheme for DES (GO HERE)
and the post Sponge layer for outflow BC (GO THERE)
but I feel to week to manage alone.
I tried grep localBlended . -R from the tutorial folder, with no success...
Some help from anybody?
I want to run a LES calculation, and I'd like to prevent the vortices (created in a turbulent wake) to "explode" when reaching the outlet. Do you have another solution than
1/ have a very long domain
and
2/ use localBlended scheme (with a dissipative linear upwind scheme for U convection)
Thanks in advance,
Julien
Djub is offline   Reply With Quote
Old   August 21, 2012, 11:19
Unhappy
Julien
sniff...
Nobody to help me...
Old   April 30, 2015, 10:03
Default Piece of code for using the localBlend scheme
Bas Nieuwboer
bjnieuwboer is on a distinguished road
Hi Julian,
I know this response is way too late for you. I hope you solved your problem. However, I had a similar problem and I saw your post without an answer. This is how I solved it. In the first 3 steps you have to edit your solver. The next steps are to create the fields itself and use the localBlended scheme
1) Go to your solver and find the file "createFields.H". This reads all the fields from your 0 folder in your simulation.
2) Attach the following piece of code to the "createFields.H" or include it from another H-file. This script reads the blendingfactors for U,k and/or epsilon. The volScalarFields to be read are called UBlend, kBlend and/or epsilon. The script then interpolates these fields to surfaceScalarFields UBlendingFactor, kBlendingFactor and/or epsilonBlendingFactor. A IOobjects called UBlendingFactor is automatically used when the scheme localBlended is used.
//BJN 2015-04-30 extra file to read the volScalarFields for the blendingfactor used for localBlended scheme. For each variable that uses the localBlended scheme, there should be a volScalarField with the blendfactor. This volScalarField can be created by for instance the funkysetfields utility of swak4foam. In this file the volumeScalarFields are interpolated to surfaceScalarFields that are needed for the localBlended scheme.
/*Usage
    div(phi,U)       Gauss localBlended linear upwind; // When blendingfactor is 1 use the first scheme. When blendingfactor is 0 use the second.
//Info<< "Reading field UBlend\n" << endl;
volScalarField UBlend
    IOobject
        "UBlend",
        runTime.timeName(),
        mesh,
        IOobject::READ_IF_PRESENT,
        IOobject::NO_WRITE
    mesh,
    dimensionedScalar("zero", dimensionSet(0, 0, 0, 0, 0, 0, 0), 0.0)
//Info<< "Transforming field UBlend to surfaceScalarField named: UBlendingFactor\n" << endl;
surfaceScalarField UBlendingFactor
    IOobject
        "UBlendingFactor",
        runTime.timeName(),
        mesh,
        IOobject::NO_WRITE
fvc::interpolate(UBlend)  // The interpolation. Please note: for the localBlended scheme to work on 'U' the variable UBlendingFactor should be present. It should be an IOobject and it should be a surfaceScalarField
//Info<< "Reading field kBlend\n" << endl;
volScalarField kBlend
    IOobject
        "kBlend",
        runTime.timeName(),
        mesh,
        IOobject::NO_WRITE
    mesh,
//Info<< "Transforming field kBlend to surfaceScalarField named: kBlendingFactor\n" << endl;
surfaceScalarField kBlendingFactor
    IOobject
        "kBlendingFactor",
        runTime.timeName(),
        mesh,
        IOobject::NO_WRITE
fvc::interpolate(kBlend)
//Info<< "Reading field epsilonBlend\n" << endl;
volScalarField epsilonBlend
    IOobject
        "epsilonBlend",
        runTime.timeName(),
        mesh,
        IOobject::NO_WRITE
    mesh,
//Info<< "Transforming field epsilonBlend to surfaceScalarField named: epsilonBlendingFactor\n" << endl;
surfaceScalarField epsilonBlendingFactor
    IOobject
        "epsilonBlendingFactor",
        runTime.timeName(),
        mesh,
        IOobject::NO_WRITE
fvc::interpolate(epsilonBlend)
3) Compile your new solver. Please follow instruction how to make a new solver elsewhere on this forum.
4) Change your div scheme in the fvSchemes. A value of 1 represents the linear discretisation. A value of 0 the upwind.
divSchemes
    default          none;
    div(phi,k)       Gauss localBlended linear upwind;
    div(phi,epsilon) Gauss localBlended linear upwind;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
5) You still have to create the fields for the blendingfactor UBlend*. I have done this using the utility swak4foam. When installed you can create your own fields.
*note, this is the volScalarField you have to specify. UBlendingFactor is the computed surfaceScalarField that is automatically used by the localBlended scheme
6) Make a input file for the swak4foam utility called funkySetFields. The input file is called: "funkySetFieldsDict". This code shows how to create the three fields.
|  \\    /   O peration     | Version:  2.3.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
expressions
    U_outer
     field UBlend; //field to initialise
     create true;
     expression "0.7";
     condition "pow(pos().x,2) + pow(pos().y,2) >= pow(1,2)";
         keepPatches 0;
    U_inner
     expression "0.8";
     condition "pow(pos().x,2) + pow(pos().y,2) < pow(1,2)";
         keepPatches 0;
    U_top
     variables "BlendTop=0;BlendBottom=0.8;ZTop=1.4;ZBottom=0;R_i=0.26;Z0=0.7;";
     expression "BlendBottom+(BlendTop-BlendBottom)/(ZTop-ZBottom)*pos().z";
     keepPatches 0;
     condition "pow(pos().x,2) + pow(pos().y,2) < pow(R_i,2) && pos().z >= 0";
    k
     field kBlend; //field to initialise
     create true;
     expression "1.0 * UBlend";
         keepPatches 0;
    epsilon
     field epsilonBlend; //field to initialise
     create true;
         keepPatches 0;
7) Run the funkySetFields utility with the command "funkySetFields -latestTime"
8) Run your model with your new solver
syavash, Pagoda, Maff and 6 others like this.
bjnieuwboer is offline   Reply With Quote
Old   February 1, 2017, 13:09
vsammartano's Avatar
Vincenzo
vsammartano is on a distinguished road
Send a message via Skype™ to vsammartano
Originally Posted by bjnieuwboer View Post
Hi Julian,
/*Usage
    IOobject
        "UBlend",
        runTime.timeName(),
        mesh,
        IOobject::NO_WRITE
    mesh,
    IOobject
        "UBlendingFactor",
        runTime.timeName(),
        mesh,
        IOobject::NO_WRITE
    IOobject
        "kBlend",
        runTime.timeName(),
        mesh,
        IOobject::NO_WRITE
    mesh,
    IOobject
        "kBlendingFactor",
        runTime.timeName(),
        mesh,
        IOobject::NO_WRITE
    IOobject
        "epsilonBlend",
        runTime.timeName(),
        mesh,
        IOobject::NO_WRITE
    mesh,
    IOobject
        runTime.timeName(),
        mesh,
        IOobject::NO_WRITE
divSchemes
    default          none;
FoamFile
    version     2;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
expressions
    U_outer
     create true;
     expression "0.7";
         keepPatches 0;
    U_inner
     expression "0.8";
         keepPatches 0;
    U_top
     keepPatches 0;
    k
     create true;
         keepPatches 0;
    epsilon
     create true;
         keepPatches 0;
Hi Bas,
first of all thank you so much for your "mini" tutorial about the generation of a "damping" zone using a velocity blending factor. I have a question about the procedure u showed in this post: you have created the blending factors using the funkySetFieldsDict, but this is only an initialization of this factors or these parameters maintain the values you took during the simulation?
Thank you for your time.
Regars, Vincenzo
vsammartano is offline   Reply With Quote
Old   February 2, 2017, 04:24
Bas Nieuwboer
Hi Vincenzo,
I indeed created the blendfactors at the start of my simulation and they are not adjusted during the simulation time. For example for U I created the UBlend using funkysetFields. In the solver this field is interpolated to the surfaceScalarField UBlendingfactor. This is automatically used by the localBlended scheme.
Regards,
Bas
Old   February 2, 2017, 04:32
Vincenzo
Hi Bas...so the blending factor works only when one start the funkySetField application? in this way we have not a permanent damping region... am i wrong?
thank you again
Vincenzo
Old   February 2, 2017, 05:34
Bas Nieuwboer
The blendingfactor works during the whole simulation. So you have a permanent damping region.
I've used the funkysetfields for creating the blend factors, because it was the easiest way to create a field for me.
vsammartano likes this.
Old   February 2, 2017, 05:50
Vincenzo
This is a really good news!! Thank you so much Bas!
Best Regards
Vincenzo
localblended ; les
non-constant blending function sven82 OpenFOAM 2 December 12, 2009 06:34
Using the localBlended scheme for DES philippebv OpenFOAM 1 November 18, 2009 13:38
localBlended braennstroem OpenFOAM Running, Solving & CFD 0 July 28, 2009 02:50
