dynamicMultiDirRefineFvMesh?
Like Tree2Likes
  • 1 Post By mturcios777
  • 1 Post By tgvosk
Old   August 30, 2012, 19:53
Default dynamicMultiDirRefineFvMesh?
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Hello all,
I'm looking for a way to dynamically refine/unrefine the mesh based on the values of a specific field (like dynamicFvRefineMesh) but to only do it in the prescribed directions.
I had three related questions:
1) Can this already be done with dynamicRefineFvMesh (i.e., is there a flag or somethign I'm missing)?
2) If #1 is false, can the arguments/inputs to hexRef8 be altered to only refine/unrefine in certain directions?
3) If #2 and #1 are false, I intend to write a new class that makes use of multiDirRefine like rhe refineMesh utility. Looking at the code for that mesh makes it look fairly easy to use, but I don't see an easy way to un-refine a region. Is un-refinement even possible?
Thanks guys, I promise to share anything that I develop that is useful...
mm.abdollahzadeh likes this.
mturcios777 is offline   Reply With Quote
Old   October 6, 2012, 15:54
Tyler V
tgvosk is on a distinguished road
Marco,
I've looked for this a little bit too, but from what I've seen:
1/2. AFAIK, no, the existing mesh refinement assumes in many places that each hex is split into 8 new cells (hexRef8, refinementHistory, and others have hard-coded the '8', and I don't see any hexRef4 that has been defined. If there was a hexRef template for D dimensions, that would be nice...)
3. Un-refinement is definitely possible, the current dynamicRefineFvMesh does this by storing the original cells from which refined cells are cut so they can be coarsened if desired. I'm not sure if refineMesh stores this information though, or just makes a new mesh.
Hope that helps a little. This would be very useful for 2D simulations!
tgvosk is offline   Reply With Quote
Old   June 22, 2016, 01:02
Francis
afrotimy is on a distinguished road
Originally Posted by tgvosk View Post
Marco,
Hi TgVosk,
I can see you have been on 2D version of dynamicRefineFvMesh.
Please do you have any development on the hexRef class for 2D AMR yet ?
afrotimy is offline   Reply With Quote
Old   August 28, 2016, 22:04
Default Re: dynamicRefineFvMesh and hexRef8 for 2D mesh
Francis
Originally Posted by afrotimy View Post
Hi TgVosk,
Just checking out on updates on hexRef for 2D refinement.
