September 11, 2012, 04:57 |
1D advection equation
Rep Power: 14 |
I´m trying to solve the onedimensional advection equation with OpenFOAM. I took following code: Code:
solve ( fvm::ddt(u) + coeff*fvc::div(u * unitVector_x) ); left boundary - fixedValue, uniform 1 right boundary - zeroGradient lower boundary - zeroGradient upper boundary - zeroGradient Normally there is should be one frontline, all values on the left of the frontline should be 1 and all values on the right 0. Does anyone have any suggestions concerning my problem? I had several ideas, why there occure this error. This equation is hyperbolic, another pde of this type is the euler-equation in rhoCentralFoam. Do I have to do some interpolation, too? Or are the numerical errors from OpenFOAM this huge? I´ve tried with a very small timestep (1e-06), too. No improvement occured regards treima |
September 12, 2012, 08:40 |
Cyprien
Rep Power: 18 |
Hi !
The equation you want to solve is hyperbolic and require a special discretization scheme like flux limiter. For exemple, if you want to solve the equation : If phi is the flux (F(S)) defined otherwise, you can set a van Leer scheme defining Code:
surfaceScalarField phiS = fvc::flux(phi/S,S, "div(phi,S)"); solve ( fvm::ddt(S) + fvc::div(phiS) ); Code:
divSchemes { div(phi,S) Gauss vanLeer; } Question about your equation : is it or ? Regards, Cyp |
September 12, 2012, 10:35 |
Hisham Elsafti
Rep Power: 17 |
On a side note: I think you should implement a generic solution (3D) and introduce the one-dimensional condition by defining all side patches (parallel to dimension of interest) as empty! Regards Hisham |
September 13, 2012, 04:37 |
Rep Power: 14 |
Thanks for your advice, it helped me a lot to solve my problem!
The background for solving the onedimensional advection equation was to have a "simple" first step into the world of hypberbolic equations in OpenFOAM. Of course it is more useful to implement a 3D solution of the problem, so it should be this equation: My code looks like the following. u is a volScalarField. Code:
volVectorField uVector (u * normalVector); surfaceScalarField phiU ("phiU", fvc::interpolate(uVector) & mesh.Sf()); surfaceScalarField phiUflux = fvc::flux(phiU, U, "div(phiU,u)"); solve ( fvm::ddt(u) + c*fvc::div(phiUflux) ); I´ve changed my boundary conditions, too. For the upper and the lower boundary I take "empty" and not "zeroGradient". Dou you have any suggestions for improving my code? As you can see in the screenshot below, this solution works for the problem shown in my first post. In the next days I´ll do some tests for other geometries and, if this works, I`ll take more complicated hyperbolic equations. regards treima |
January 6, 2019, 10:20 |
Reviewer #2
Rep Power: 10 |
I know this is an old post. But I think what this post discussed (one direction reconstruction) will not be sufficient for handling the hyperbolic system. It may work in this simple testing case. The multi-direction reconstruction should be implemented, such as MUSCL. And then either solve/approximate the local Riemann problem at the interface or use some sort of Riemann-free technique, such as Kurganov and Tadmor central scheme (what used by rhoCentralFoam). However, the entropy satisfied the weak solution is not guaranteed until some other fix is introduced. Thanks, Rdf |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Model crashes while solving advection diffusion equation | cooljd | Main CFD Forum | 3 | August 23, 2012 10:40 |
Total variation diminishing scheme for advection or advection dispersion equation | cooljd | Main CFD Forum | 7 | July 27, 2012 08:32 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
