problem with using exp() function
Like Tree3Likes
  • 3 Post By ngj
Old   September 26, 2012, 04:27
Unhappy problem with using exp() function
reza
sasookey is on a distinguished road
Hi
Im new user, and i use OpenFoam2.01
I want to make a new solver and when I use exp function every where in my program such as this:
forAll( Utot , celli ) {
if (Utot[celli] < exp(0.1) ) {
where Utot is a volScalarField,
I got this error when I want to wmake it :
pEqn.H:100: error:call of overloaded 'exp(double)' is ambiguous
but if I remove exp() or use sqr() function i got no error !
I need exp in my solver and I cant use the answer of exp(0.1) and I don't know how to use it.
very thanks to help me.
sasookey is offline   Reply With Quote
Old   September 26, 2012, 04:43
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Reza,
It is because your compiler is confused, whether you want to use std::exp or Foam::exp versions of the exponential. Merely replace "exp" with "Foam::exp" and it will compile.
Kind regards,
Niels
babakflame, Kirils and a.Asadi like this.
ngj is offline   Reply With Quote
Old   October 1, 2012, 12:19
Smile
reza
dear Niels
very thanks to help me, I try that and it worked.
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
OpenFoam 14 installation problem gfcoppola OpenFOAM Installation 20 November 2, 2007 13:38
Problem in CFX5POST Chart function. windhair CFX 2 September 20, 2004 07:49
