high-order difference in OpenFOAM
Like Tree1Likes
  • 1 Post By reza_65
Old   January 9, 2013, 06:53
Default high-order difference in OpenFOAM
ren XG
rxgrch is on a distinguished road
I want to implement a high-order difference sheme which is 4 or 5 order, but it seemed that the difference order is just up to 3 order, the difference template in OpenFOAM now is just two cells, but the high order(4or5) will need more than 3 neighbor cells, so who can tell me how to implement the high order difference with the smallest modify with the current C++ code?
rxgrch is offline   Reply With Quote
Old   January 10, 2013, 10:08
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
Hello, i tried to implement high-order schemes in OpenFOAM (WENO + k-exact) one year ago, but i found, that i don't know how to select proper stencil for scheme. If You will help with mathematics, then i can help you with implementation
mkraposhin is offline   Reply With Quote
Old   January 24, 2013, 01:45
ren XG
Thank you for your reply, and I don't quite get what do you mean " i don't know how to select proper stencil for scheme"? the scheme that we want to implement is WCNS scheme. So can you give me some advice or with a example code of high-order sheme? Thanks very much!
Old   March 26, 2013, 21:07
ren XG
what you said had been solved in a paper "High Order Schemes on Three-Dimensional General Polyhedral Meshes—Application to the Level Set Method", it maybe help you.
Old   July 8, 2016, 12:50
Reza khodadadi
reza_65 is on a distinguished road
Send a message via ICQ to reza_65 Send a message via AIM to reza_65 Send a message via Yahoo to reza_65
Can I ask you whether you have implemented this high order (WENO) method within OpenFOAM, or not yet? If yes, can you please kindly tell me is it available somewhere?
Regards,
Reza
reza_65 is offline   Reply With Quote
Old   October 10, 2016, 23:48
Default WENO in openFoam
Mohit Kumar Singh
Mohit.singh is on a distinguished road
Originally Posted by reza_65 View Post
Regards,
Reza
Hello, Were you able to implement WENO scheme in OpenFOAM?
Mohit.singh is offline   Reply With Quote
Old   August 28, 2017, 14:11
Reza khodadadi
Hi there,
You can find some suitable information in the post below:
https://www.cfd-online.com/Forums/op...-problems.html
Regards,
Reza
Gang Wang likes this.
difference sheme
how to understand high resolution scheme and high order scheme iilw1314 Main CFD Forum 7 April 12, 2022 12:29
Implementing third order derivatives in OpenFOAM asmale OpenFOAM Programming & Development 2 November 7, 2013 16:21
what is the difference between flat, first and fifth order wave in STAR CCm+ ?? sanjay Siemens 1 January 19, 2012 17:48
High order methods in commercial use? cfdnewbie Main CFD Forum 5 January 12, 2012 05:51
High order FVM scheme .... cfd_newbie Main CFD Forum 2 February 6, 2008 06:46
