How to rotate a pointScalarField?
Old   January 25, 2013, 00:53
Question How to rotate a pointScalarField?
carowjp's Avatar
Jim Carow
carowjp is on a distinguished road
Hello.
Can anyone please tell me how to rotate a pointScalarField?
I need to keep the mesh fixed and rotate the scalar contents of a field. So for example if you use setFields with boxToCell to set the value of 1 in the box and 0 elsewhere , I would like to then change the orientation of the volScalarField 'box' keeping the mesh fixed.
My idea was to use volPointInterpolation to interpolate cell center values to a pointScalarField, rotate the pointScalarField, and finally interpolate back to the cell centers using pointVolInterpolation.
Thanks for any suggestions on how to accomplish this.
Jim
carowjp is offline   Reply With Quote
Old   January 25, 2013, 17:24
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
Hi Jim,
Just out of curiosity what is it you are trying to do?
One option for rotating the 'box' would be to advect it with an applied rotational velocity field. This would be pretty analogous to the "zalesak's disk" test which is common in multiphase alg. testing. Give it a google and you should see what I mean.
Cheers!
Kyle
kmooney is offline   Reply With Quote
Old   January 25, 2013, 17:44
Default How to rotate a pointScalarField?
carowjp's Avatar
Jim Carow
Kyle,
Thanks for your reply.
I am trying to accomplish rotation of a scalar field at constant rate about a fixed point.
I basically want to calculate the rotated positions of the cell centers and interpolate the values of those grid points back onto the original non-rotated grid.
I would like to do accomplish the result if possible without advecting the field to avoid numerical diffusion, especially since the transformation is constant and known in advance.
Any ideas would be appreciated.
The application I am working on is flow induced by a moving rigid body using a non-body fitted grid and a volume penalization method. The body is represented by a phase fraction and a forcing term is added to the momentum equation.
thanks and regards,
Jim
Old   January 25, 2013, 18:09
kmooney's Avatar
Kyle Mooney
Hi Jim,
It sounds like this might be done with some kind of mapping approach.
http://www.openfoam.org/docs/user/mapFields.php
The link shows a console level example but what you would want is something that occurs during runtime. You could probably figure it out from the mapFields source.
Off the top of my head this is what I'm thinking (don't hold me to it):
Start your run with your initial box'd field. Instantiate a second, new mesh that is a copy of the first. Rotate the new mesh. Map the new mesh's field onto the old mesh. Delete the new mesh.
Rinse and repeat.
Just an idea!
Cheers!
Kyle
Old   January 27, 2013, 13:42
carowjp's Avatar
Jim Carow
Ok, this is as far I have gotten. If there are better ways I would appreciate learning them My doubts are in the copying of a mesh instance and the meshToMesh interpolation.
    Foam::fvMesh mesh
        Foam::IOobject
            Foam::fvMesh::defaultRegion,
            runTime.timeName(),
            runTime,
            Foam::IOobject::MUST_READ
    Foam::fvMesh meshR
        Foam::IOobject
            runTime.timeName(),
            runTime,
    pointField meshPoints(meshR.points());
   // volume fraction of embedded body
    volScalarField alpha
        IOobject
            "alpha",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
            IOobject::AUTO_WRITE
        mesh
   // not sure how to properly 'copy' an instance of a mesh and its fields
    volScalarField alphaR   // Volume fraction of body in mesh to be rotated
        IOobject
            "alphaR",
            runTime.timeName(),
            meshR,
            IOobject::NO_READ,
        alpha
    const scalar theta = 45;
    const scalar angle = Foam::cos(theta/2);
    vector axis = vector(0, 0, 1);
    quaternion Rotation(axis,angle);
    tensor R = Rotation.R();
    meshPoints = transform(R, meshPoints);
    meshR.movePoints(meshPoints);            // not sure if this line is necessary
    meshToMesh  meshToMeshInterp(meshR, mesh);
    Info << "interpolate from meshR to mesh." << endl;
    meshToMeshInterp.interpolate(alphaR, alpha, meshToMesh::INTERPOLATE);
Regardless of the order of alpha & alphaR in the arguments I have a crash at the last line of code:
 --> FOAM FATAL ERROR:
the argument field does not correspond to the right mesh. Field size: 529200 mesh size: 529200
From function meshToMesh::interpolateInternalField(Field<Type>& toF, const GeometricField<Type, fvPatchField, volMesh>& fromVf, meshToMesh::order ord) const
in file /home/carowjp/OpenFOAM/OpenFOAM-2.1.1/src/sampling/lnInclude/meshToMeshInterpolate.C at line 129.
This problem is mentioned in the thread: http://www.cfd-online.com/Forums/ope...time-step.html but no solution was posted.
thanks for any tips,
Jim
Old   January 27, 2013, 19:49
Question how to "Instantiate a second, new mesh that is a copy of the first"?
carowjp's Avatar
Jim Carow
If I change the initial values of the field on the mesh to be rotated as:
    volScalarField alphaR   // Volume fraction of body in rotated mesh
        IOobject
            "alphaR",
            runTime.timeName(),
            meshR,
            IOobject::NO_READ,
        meshR,
        scalar(1)  // was alpha
and use this field order in the arguments:
meshToMeshInterp.interpolate(alpha, alphaR, meshToMesh::INTERPOLATE);
The code in the previous post will run as a silly test case. Although it produces incorrect results if run in parallel.
What I am missing though is how to "Instantiate a second, new mesh that is a copy of the first" which also has the values of the field alpha on the original mesh?
thanks,
Jim
Last edited by carowjp; January 28, 2013 at 21:01. Reason: Note: produces incorrect results if run in parallel
pointscalarfield
Writing scalarField values into a pointScalarField Arnoldinho OpenFOAM Programming & Development 6 October 22, 2019 03:38
const_cast and pointScalarField myheroisalex OpenFOAM Programming & Development 3 April 26, 2016 11:02
surfaceTransformPoints -rotate ynos OpenFOAM Post-Processing 1 July 11, 2012 15:35
[GAMBIT] Rotate and revolute possible ? Ijaz ANSYS Meshing & Geometry 19 January 26, 2012 23:36
[ANSYS Meshing] meshing for rotate and revolute Ijaz ANSYS Meshing & Geometry 0 December 25, 2011 16:51
