??fvVectorMatrix+fvVectorField??
Like Tree1Likes
  • 1 Post By ngj
Old   February 17, 2013, 16:52
Default ??fvVectorMatrix+fvVectorField??
Alexander
Svensson is on a distinguished road
Send a message via Skype™ to Svensson
Hello All!
I try to remake the icoFoam solver to an solver for stratified almost incompressible liquid and I've an following problem:
I added a new term to momentum equation, which is defined as: - rhoMin+f*(rhoMax-rhoMin)-rho0)/rho0*g
(where rhoMin, rhoMax, rho0 are a constants)
And if I write the momentum equation a intuitive way:
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
- fvm::laplacian(nu, U)
solve(UEqn == -fvc::grad(p)+ (rhoMin+f*(rhoMax-rhoMin)-rho0)/rho0*g );
dimensionedScalar ks=nu/1000;
fvScalarMatrix SEqn
fvm::ddt(f)
+ fvm::div(phi, f)
- fvm::laplacian(ks, f)
SEqn.solve();
Solver doesn't work well (velocity is induced, but scalar f isn't transfered)
But if we write the equation as follows
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
solve(UEqn == -fvc::grad(p));/////////////////////////////////////////////////
fvScalarMatrix SEqn
fvm::ddt(f)
+ fvm::div(phi, f)
SEqn.solve();
Solver works normally!
And for me it's realy strange, because expression - fvm::laplacian(nu, U)- rhoMin+f*(rhoMax-rhoMin)-rho0)/rho0*g means that we add matrix coefficient to vector.
Svensson is offline   Reply With Quote
Old   February 18, 2013, 01:53
Bernhard
Bernhard is on a distinguished road
All of the terms are vectors, i.e. the Laplacian of a vector is a vector and your custom term is also a vector, since you include g. Is this what your confusion is about?
Bernhard is offline   Reply With Quote
Old   February 18, 2013, 02:18
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Alexander,
I suppose that you question is about two "identical" modifications to the momentum equation, however, you get two different results on the flow field, correct?
The second implementation is the correct one to choose, simply because you are otherwise solving a pressure equation, which do not know about the additional source term. When you put the source inside fvVectorMatrix, it works correctly with respect to the pressure-velocity coupling.
Kind regards
Niels
sharonyue likes this.
ngj is offline   Reply With Quote
