Problem using atmBoundaryLayerInletVelocity
Old   February 28, 2013, 09:21
Default Problem using atmBoundaryLayerInletVelocity
zako
bigzakk is on a distinguished road
I am trying to use atmBoundaryLayerInletVelocity for a very simple application however I am receiving this error i cant figure out. Thanks for any helps however small
Create time
Create mesh for time = 0
Reading field p
Reading field U
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 log in "/lib/x86_64-linux-gnu/libm.so.6"
#4 Foam::incompressible::atmBoundaryLayerInletVelocit yFvPatchVectorField::atmBoundaryLayerInletVelocity FvPatchVectorField(Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#5 Foam::fvPatchField<Foam::Vector<double> >::adddictionaryConstructorToTable<Foam::incompres sible::atmBoundaryLayerInletVelocityFvPatchVectorF ield>::New(Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#6 Foam::fvPatchField<Foam::Vector<double> >::New(Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/pisoFoam"
#7 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricB oundaryField(Foam::fvBoundaryMesh const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/pisoFoam"
#8 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readField(Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/pisoFoam"
#9 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readField(Foam::Istream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/pisoFoam"
#10 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/pisoFoam"
#11
#12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#13
Floating point exception (core dumped)
bigzakk is offline   Reply With Quote
Old   March 3, 2013, 16:43
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Zako,
"Floating point exception" is code for divide by zero or some other undefined numerical error. If you have something like a z0 = 0 and Href = 0 then there is going to be a log(0) in there for that BC. I tend to use 1e-20 instead of zero for small numbers that may induce this kind of error. Have a look at the BC itself in
$FOAM_SRC/turbulenceModels/incompressible/RAS/derivedFvPatchFields/atmBoundaryLayerInletVelocity
to track down exactly where this error is. Without seeing how you have defined the BC...I can't give you more info than this. Good Luck.
chegdan is offline   Reply With Quote
Old   March 4, 2013, 06:40
zako
Thanks a million its works
Old   March 9, 2013, 06:40
Default Problem with atmBoundaryLayerInletVelocity
Korichi Abdelkader
AbdelkaderDZ is on a distinguished road
Hi anyone,
I have error at the forth iteration when using atmBoundaryLayerInletVelocity for a simple case I use simpleFoam solver. Anyone can help me
ime = 4
DILUPBiCG: Solving for Ux, Initial residual = 0.0747753, Final residual = 0.00352462, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.0842028, Final residual = 0.00496445, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.00994555, Final residual = 9.80074e-05, No Iterations 225
time step continuity errors : sum local = 0.0137186, global = 0.000340224, cumulative = -0.000110142
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
AbdelkaderDZ is offline   Reply With Quote
Old   March 9, 2013, 13:46
Lieven
Lieven will become famous soon enough
Welcome to the forum AbdelkaderDZ.
For the looks of it, there is something wrong with your continuity. The cumulative error is simply way too big. If you are using a standard solver, this is often caused by incompatible boundary conditions. Could you post an overview of them of all fields (pressure, velocity, ...)?
Cheers,
L
Lieven is offline   Reply With Quote
Old   March 10, 2013, 02:10
Default Re:Re:Problem with atmBoundaryLayerInletVelocity
Korichi Abdelkader
Thank you Lieven
I have used the standard simplefoam with the following boundary condition for u and p:
u boundary condition:
boundaryField
#include "include/ABLConditions"
outlet
type zeroGradient;
inlet
type atmBoundaryLayerInletVelocity;
Uref $Uref;
Href $Href;
n $windDirection;
z $zDirection;
z0 $z0;
value $internalField;
zGround $zGround;
upperWall
type symmetryPlane;
lowerWall
type fixedValue;
value uniform (0 0 0);
frontAndBack
type empty;
p boundary condition
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
upperWall
type symmetryPlane;
lowerWall
type zeroGradient;
frontAndBack
type empty;
Old   March 10, 2013, 04:31
Lieven
Nothing seems spectacular wrong with this so here are a few things you can do/check:
Does 'checkMesh' return 'mesh ok' (maybe post the final summary)?
Do you get the same problem when running with smaller time step?
One thing you can do is run your application using pimpleFoam instead of simpleFoam, which runs often more stable for larger time steps. Can you post the output of this here?
Which turbulence model are you using?
Chees,
L
Old   November 11, 2019, 17:34
Default ATMBoundarylayer error
marco velazquez
marco-vs is on a distinguished road
Hi Bigzakk,
please can you tell me how to solve "atmBoundaryLayerInletVelocity" issue, What did you change o installed?
thanks
marco-vs is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
