How to get the value of deltaT in OpenFOAM?
Like Tree15Likes
  • 7 Post By fumiya
  • 6 Post By fumiya
  • 2 Post By alundilong
Old   March 2, 2013, 01:31
Question How to get the value of deltaT in OpenFOAM?
anonymous
shchao is on a distinguished road
Dear FOAMers:
I want to use the value of deltaT, known as time steppness ,while calculation in fvMotionSolver lib.Does OpenFOAM define this varible?Or How can I calculate the time stepness, esspecially in interFoam?Thank you!
shchao is offline   Reply With Quote
Old   March 2, 2013, 02:44
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
You can use runTime.deltaTValue().
fumiya is offline   Reply With Quote
Old   March 2, 2013, 03:57
Exclamation Thank you for your reply but it seems there's a little problem
anonymous
Hi,Fumiya!
Thank you for your reply!
I'm using a piston-type wavemaker derived from oscillatingDisplacement in fvMotionSolver.When i add runTime.deltaTValue() into the code and excute the wmake libso command.It returns an error --'runTime' doesn't declare in this scope.I have include the setDeltaT.H in the file.
Old   March 2, 2013, 04:56
fumiya's Avatar
Fumiya Nozaki
Hi shchao,
How about this->db().time().deltaTValue()?
Fumiya
Old   March 2, 2013, 05:40
Thumbs up It works!Thank you!
anonymous
Hi,Fumiya
I've modified the code as you said. And it works.Thank you sincerely!
Old   November 5, 2013, 07:59
Jarvis
nbyjn is on a distinguished road
Originally Posted by shchao View Post
Hi,Fumiya!
Hi shchao,
Glad to meet you! I'm also using a piston-type wavemaker by interDyMFoam.
But I have two questions:
1.At the starttime, the piston(left boundary) moves rightward, so the water level should rise. But in fact, the water goes down! Do you have the same question?
2.interDyMFoam change the timestep automaticly, so the slover runs slower and slower. It's so slow that it can't calculate for 0.1s in a whole night! Can you give me some advice?
Thank you very much!
nbyjn is offline   Reply With Quote
Old   October 12, 2014, 08:04
Ed Ransley
Ed R is on a distinguished road
Hi all,
I'm trying to use deltaT in a restraint on sixDoFRigidBodyMotion solver. I've tried both the runTime.deltaTValue() and db().time().deltaTValue() and neither runTime nor db are define in the scope.
Which .H files do I need to include in order to use runTime or is it significantly more difficult than that?
Thanks,
Ed
Ed R is offline   Reply With Quote
Old   January 14, 2016, 13:09
yijin Mao
alundilong is on a distinguished road
you might try.
runTime.time().deltaT();
if you need scalar
runTime.time().deltaT().value();
Originally Posted by Ed R View Post
Hi all,
Thanks,
Ed
stanweer and sultimate like this.
alundilong is offline   Reply With Quote
Old   March 19, 2021, 08:31
Guanwen Luo
zzluozz11 is on a distinguished road
Originally Posted by alundilong View Post
you might try.
if you need scalar
Hi, I got an error "runtime was not declared in this scope", eventhough I add the head file "time.h". Please tell me how to deal with it. Thanks.
zzluozz11 is offline   Reply With Quote
Old   March 7, 2022, 07:15
ali moeni is on a distinguished road
Hi
You can try runTime.deltaT(), but I'm not sure if it works
ali moeni is offline   Reply With Quote
Old   March 7, 2022, 09:32
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Sure, but runTime is a variable. See for example,
https://www.openfoam.com/documentati...8H_source.html
olesen is offline   Reply With Quote
Old   August 26, 2022, 03:02
Gavin.
GavinRe is on a distinguished road
I need help setting up my deltaT, maxCo and maxAlphaCo(?) for my simulation. I am trying to simulate flow across a vertical cylinder ; which I based on interFoam/RAS/weirOverFlow tutorial.
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  9
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     interFoam;
startFrom       latestTime;
startTime       0;
stopAt            endTime;
endTime         1;
deltaT             0.01;
writeControl    adjustableRunTime;
writeInterval    0.1;
purgeWrite       0;
writeFormat     binary;
writePrecision   6;
writeCompression    off;
timeFormat       general;
timePrecision    6;
runTimeModifiable yes;
adjustTimeStep  on;
maxCo             0.2;
maxAlphaCo     0.2;
maxDeltaT       1;
The solver stop halfway and when I tried running my simulation on paraview, the water does not rise/flow.
GavinRe is offline   Reply With Quote
feature or bug - deltaT issue lakeat OpenFOAM Running, Solving & CFD 29 August 8, 2020 01:34
openfoam 1.5-dev on opensuse10.3-64bit anon_c OpenFOAM 2 December 4, 2009 00:33
Issues with OpenFoam sanjibdsharma OpenFOAM 0 August 14, 2009 08:41
2009 OpenFOAM Summer School in Zagreb, Croatia hjasak OpenFOAM Announcements from Other Sources 0 March 27, 2009 12:08
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
