Linker Problem??
Old   March 21, 2013, 04:47
Default Linker Problem??
Peter Müller is on a distinguished road
Hi
I created a boundary condition and was able to compile and use it with OF1.5 OF1.6 and OF2.1 but I get problems since I tried to port it to OF2.2.
I want to compile an application which is using the boundary condition that I implemented but during compilation I always get the error:
OpenFOAM-2.2.x/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libMPImp.so: undefined reference to `vtable for Foam::impMPPolyPatch'
OpenFOAM-2.2.x/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libMPImp.so: undefined reference to `typeinfo for Foam::impMPPolyPatch'
Does anybody have an idea why this happens?
Thanks in advance
Peter
Peter Müller is offline   Reply With Quote
Old   March 22, 2013, 12:03
Jim Knopf
JimKnopf is on a distinguished road
Hi Peter,
your question is a bit difficult to answer.
Does your BC use the libMPImp in any way?
Did you include the correct libs in Make/option?
What is your BC doing?
Is the Bc compiled as a dynamic library or just included in the solver?
Best regards,
Jim
JimKnopf is offline   Reply With Quote
Old   April 3, 2013, 07:02
Hi Jim
I thought its a bit tricky but I could not figure out where to start since I completely did/do not understand the problem. I created a boundary condition (a mixing plane for turbomachinery) which is compiled as a shared library named libMPImp.so.
In my solver and some utilities I need to include this boundary condition. But when I tried to compile the solver/utility I always got this error.
I do not know where the error came from. Finally I cleaned my boundary to more or less empty, compiled it and also the solver and got no error. I put in the rest piece by piece and as far as I know ended up with the same as I had before removing and now it works. No idea where the problem was. Compilation issue, directory of the libMPImp.so (FOAM_LIBBIN or FOAM_USER_LIBBIN) no idea.
Thank you anyway
Peter
Old   April 3, 2013, 09:58
Jim Knopf
Hi Peter,
sounds a bit strange, but if it works, it works. Maybe you missed a removal of .dep files or something.
Greetz
Jim
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
