Proper Referencing of Custom Libraries in Options File
Like Tree1Likes
  • 1 Post By ngj
Old   March 31, 2013, 11:10
Default Proper Referencing of Custom Libraries in Options File
Cameron
c_dowd is on a distinguished road
Hi all,
I'm trying to build an incompressible form of the firefoam solver, to do this i've edited the combustion model I want to use and compiled it as a new library. I'm trying to compile my edited version of the firefoam solver and I'm not sure if i'm referencing the library properly. The way I'm doing it at the moment is:
EXE_LIBS = \
    -L$(FOAM_USER_LIBBIN)/customcombustionModels \
    -lincompressibleTransportModels \
    -lincompressibleTurbulenceModel \
    -lincompressibleRASModels \
    -lincompressibleLESModels \
Is that how it should be or is there some other way?
c_dowd is offline   Reply With Quote
Old   March 31, 2013, 18:31
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Cameron,
No, I think you will be running into troubles in this way. I have successfully been using the following format previously with the original libraries first and then your custom libraries:
LIBS = \
    -L$(FOAM_USER_LIBBIN) \
    -lcustomcombustionModels
Note, that once you have defined the line "-L$(FOAM_USER_LIBBIN)" you can add any number of custom libraries following this line.
Kind regards,
Niels
nimasam likes this.
ngj is offline   Reply With Quote
Old   March 31, 2013, 19:37
Cameron
Thanks a lot, that got it sorted.
compiling, firefoam, incompressible, libraries
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
