Indentify internal field value at specific patch
Like Tree9Likes
  • 2 Post By Giancarlo_IngChimico
  • 1 Post By immortality
  • 1 Post By Giancarlo_IngChimico
  • 1 Post By Lieven
  • 1 Post By ngj
  • 1 Post By fredo490
Old   April 11, 2013, 17:18
Post Indentify internal field value at specific patch
Giancarlo
Giancarlo_IngChimico is on a distinguished road
Hi guys,
I have a patch named "fluid_to solid" in my mesh. In order to copy the values of a field in correspondence to this specific field I have written the following code:
forAll( TFluid[j].boundaryField(), patchi)
        label patchID = fluidRegions[j].boundaryMesh().findPatchID("fluid_to_solid");
        forAll( TFluid[j].boundaryField()[patchID], facei)
                Tf[facei+1] = TFluid[j].boundaryField()[patchID][facei];
It seems to work fine.
My problem now is copy the internal values of the same field at the patch "fluid_to_solid"...
Can anyone help me?
Best
Giancarlo
immortality and Zhiheng Wang like this.
Giancarlo_IngChimico is offline   Reply With Quote
Old   April 13, 2013, 13:54
immortality's Avatar
Ehsan
immortality is on a distinguished road
i need to do such work.i didn't grasp.what does this code do exactly? And where in code should it be added?(i use rhoPimpleFoam)
Thanks.
Zhiheng Wang likes this.
immortality is offline   Reply With Quote
Old   April 13, 2013, 20:05
Giancarlo
This is my solver that I have developed. I need to know the value of internalField only of the cells located at interface. (named "fluid_to_solid")
Old   April 13, 2013, 20:28
Lieven
Lieven will become famous soon enough
Hi Giancarlo,
I hope this is what you were looking for. Once you have the right patchID you can use something like:
const fvPatchVectorField& Uw = U.boundaryField()[patchI];
forAll(Uw,faceI)
    // The value inside the cell
    const scalar& Up = Uw.patchInternalField()[faceI];
It's just from the heart, I haven't tested it so it might not compile immediately but this might give you a direction.
Cheers,
L
Lieven is offline   Reply With Quote
Old   April 14, 2013, 04:47
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Good morning,
As an alternative, you can also work with the faceCells in case you have access to the whole of the volume field. This goes something along these lines, and assume that you have a fvPatch called "patch".
const polyPatch & pp = patch.patch();
const labelList & faceCells( pp.faceCells() );
forAll( faceCells, facei )
    // A bit of pseudo code
    myBoundaryField[facei] = someOperation<myVolumeField[faceCells[facei]]>;
This piece of code is particular interesting, if the volume field, which you need to access, is not the field on which the boundary condition is defined. E.g. accessing the velocity field in the boundary condition for pressure.
Kind regards
Niels
ngj is offline   Reply With Quote
Old   April 14, 2013, 06:10
Giancarlo
Thanks all,
I have solved in this manner:
const fvPatchList& patches = fluidRegions[j].boundary();
    forAll(patches, patchI)
        const fvPatch& cPatch = patches[patchI];
        if(cPatch.name() == "fluid_to_solid")
        forAll(cPatch, celli)
        Tf[celli+1] = TFluid[j].internalField()[celli];
Kind regards
Giancarlo
Zhiheng Wang and ruloz like this.
Old   April 16, 2013, 12:29
HECKMANN Frédéric
fredo490 is on a distinguished road
I use this kind of code, I don't know if it works for multi region mesh:
label patchWall = mesh.boundaryMesh().findPatchID("wall"); //patchID = id of the patch wall
const fvPatch& cPatch = mesh.boundary()[patchWall];
    forAll(cPatch, facei) //facei = id of the face
You can maybe adapt it to include your region selection.
fredo490 is offline   Reply With Quote
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
error message cuteapathy CFX 14 March 20, 2012 06:45
[blockMesh] Cyclic BC's: Possible face ordering problem? (Channel flow) sega OpenFOAM Meshing & Mesh Conversion 3 September 28, 2010 12:46
chtMultiRegionFoam Tutorial m.nichols19 OpenFOAM 12 September 9, 2010 11:56
