September 11, 2013, 10:29 |
developing doc
Yu CAO
Hi
I am wondering if openfoam1.6-ext and online doc cpp like the link below? http://www.openfoam.org/docs/cpp/ Thanks |
September 11, 2013, 10:47 |
Bernhard
Rep Power: 21 |
I am not aware of one, but with Doxygen you can generate it yourself.
September 11, 2013, 11:42 |
Hassan
How can I use the Doxygen in my pc without internet? thanks, Hassan |
September 11, 2013, 11:47 |
#4 | |
Yu CAO
Detailed Description template<class Type> class Foam::fixedGradientFvPatchField< Type > This boundary condition supplies a fixed gradient condition, such that the patch values are calculated using: where = patch values = internal field values = gradient (user-specified) = inverse distance from patch face centre to cell centre |
September 12, 2013, 01:34 |
Bernhard
Rep Power: 21 |
I don't know where you found it, but the linked doc cpp is created using Doxygen. That is just a tool that generates this documentation based on the source code, so it work on any C++ source code.
@lcukycfd: As soon as you downloaded and installed Doxygen, you can use it offline. |
September 12, 2013, 03:09 |
Christian Lucas
a user-driven documentation project for OpenFOAM is the CoCoon project. http://www.cfd-online.com/Forums/ope...echnology.html Christian |
September 12, 2013, 06:32 |
#7 | |
Yu CAO
I think this project is newly created, isn't it? I am not sure if it support extention version of OpenFOAM. I am just wondering if there exist one website supporting openfoam-1.6-ext similar to the link I provided above. Thanks Yu |
September 12, 2013, 06:43 |
Christian Lucas
it supports OpenFOAM ext. The same guys are behind both projects Regards, Christian |
Need for some tutorials on solver developing | ooo | OpenFOAM Programming & Development | 1 | June 20, 2013 09:16 |
Spatially Developing Turbulent Boundary Layer Inlet | deji | OpenFOAM | 1 | June 8, 2010 14:52 |
Fully Theramlly developing How find | Emad | FLUENT | 0 | January 22, 2009 09:15 |
Developing flow in channels benchmark | Ted | Main CFD Forum | 0 | July 24, 2003 15:59 |
Where can I find Airpak help doc. and tutorials? | Hotlood Wong | FLUENT | 3 | April 23, 2001 03:55 |
