How can I solve non-dimensional equations in FOAM
Old   October 28, 2013, 04:17
Default How can I solve non-dimensional equations in FOAM
Sean McGinty
mcgintygs is on a distinguished road
I'm interested in solving (as a starting point) a non-dimensionalised version of laplacianFoam.
After I have chosen my non-dimensionalisation, how can I implement this in Foam?
I'm worried that foam checks dimensions!
For example:
How do I change the timestep and spatial coordinates (in blockMeshDict) to be non-dimensional, and how do I deal with diffusion coefficients (which will become ratios of diffusion coefficients after the non-dimensionalisation)
Is it possible to do this. Does anyone know how?
Any help would be much appreciated.
mcgintygs is offline   Reply With Quote
Old   October 28, 2013, 15:02
Jack
ripperjack is on a distinguished road
For example:
You need to do some modification on the solver, e.g., change nu to 1/Re, change kappa to Pr, etc. The equations have very similar form the only different is the coefficient, so it can be done without large modification.
Do not change the unit of variables!
Regards,
ripperjack is offline   Reply With Quote
Old   October 28, 2013, 16:08
Lieven
Lieven will become famous soon enough
As far as I know you can't. In blockMesh you could use the convertToMeters parameter if you want to enter the coordinates with the dimensionless values, but the dimensions will always be kept as meters.
Second, you could change all the equations you want to solve ... but alternatively you could also simply solve the existing equations and rescale your solution when writing the solution. That works best for me (for one reason, you'll always be stuck with the time derivative and nabla operator which keep their dimensions).
Cheers,
Lieven
Lieven is offline   Reply With Quote
Old   March 20, 2014, 06:29
Tony
wzx1989221 is on a distinguished road
Hi Lieven,
I just wonder how did you rescale your solution? Can you give me a hint please?
Thank you very much.
Kind regards,
Tony
wzx1989221 is offline   Reply With Quote
Old   March 22, 2014, 07:23
Lieven
Hi Tony,
Have a look at http://en.wikipedia.org/wiki/Dimensional_analysis
Basically, you rescale your solution by multiplying it with reference quantities. For example, a concentration in [kg/m³] can be rescaled as:
c+ [-] = c [kg/m³]* L² [m²]*V[m/s] / R [kg/s]
where L is a reference length (e.g. stack height, when it concerns the release of a pollutant from a stack), V is a reference velocity (e.g. velocity at the tip of a stack) and R is the release rate.
This is merely an example but I hope you got the picture.
Cheers,
L
Old   March 22, 2014, 07:35
Tony
Hi Lieven,
It is really nice of you to give me the explanation. My case is I want to rescale my result to nondimensional value and continue the simulation, I wonder how you achieve it in OpenFOAM? I have done nondimensionalisation for U, p fields and geometry size, however, the simulation didn't run continuously. The simulation should continue without gap, right?
Kind regards,
Tony
USER_FORTRAN solve iteratively a linear equations system fipellac CFX 9 June 12, 2019 07:03
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 04:20
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
ansys to foam and solve with dsmc dark lancer OpenFOAM Pre-Processing 0 October 21, 2012 16:07
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
