automatic interpolation of field on call
Old   November 29, 2013, 09:54
Default automatic interpolation of field on call
romant's Avatar
Roman Thiele
romant is on a distinguished road
I have a question. Let's say I have a field
const volScalarField& k
and I have a some labels, let's call them
label faceI        // surface between two cells
label faceCellI   // cell center
when I now call
k[faceCellI]
I get the value of k at the cell center, as the label points to a cell center. When I call
k[faceI]
do I get the interpolated value from the face? I always thought that I would need to interpolate the field first and then call the interpolated field in order to get my value at the interface between two cells. However, after implementing it this way, I still get a value, which also seems reasonable.
Now the question, does OpenFOAM automatically interpolate in these cases? I wonder if the same also works for volVectorFields, when retrieving a value from the interface between two neighboring cells (through a label) that it then interpolates.
~roman
romant is offline   Reply With Quote
Old   November 29, 2013, 10:23
akidess's Avatar
Anton Kidess
Both faceI and faceCellI in your example are labels (this pretty much is equal to a integer). Suppose faceI = 1, and faceCelli = 1, how would the code you show know if it's supposed to return a interpolated or cell centre value? Keep in mind the code doesn't know the name of your variable, only the location in memory. Thus, from the very brief snippets you show, you should get the cell centre value in both cases.
- Anton
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   November 29, 2013, 10:30
romant's Avatar
Roman Thiele
- Anton
This is what I thought as well, however. The reason I got to this point is because when I interpolated value for k onto a surface mesh, and then used the faceI value, I ended up getting a temperature value :-)
I am using this method http://www.cfd-online.com/Forums/ope...tml#post254946 to find the global indices for the cell interface opposite to the patch on a boundary. With this label I then would like to retrieve the velocity and k. At first I thought this should work very easily by using the interpolated (onto the surface mesh) fields in combination with the label oppFaceI which I retrieve from the mentioned method
~roman
Old   November 29, 2013, 12:32
akidess's Avatar
Anton Kidess
Please post the code as you have implemented it.
Old   November 29, 2013, 12:44
romant's Avatar
Roman Thiele
I think I have found my answer, however, here comes the code
// get access to the mesh for opposite faces
    const fvMesh& mesh = patch().boundaryMesh().mesh();
    // access to everything else
    const turbulenceModel& turbModel =
        db().lookupObject<turbulenceModel>("turbulenceModel");
    const tmp<volScalarField> tk = turbModel.k();
    const volScalarField& k = tk();
    const surfaceScalarField kSurface = fvc::interpolate(k);
forAll(mutw, faceI)
        label faceCellI = patch().faceCells()[faceI];
        label oppFaceI =
            mesh.cells()[faceCellI].opposingFaceLabel
                faceI+patch().patch().start(),
                mesh.faces()
        // calculate distance between wall and opposing face
        // get coordinates of centre of face opposite the patch boundary face
        vector faceCentre  = mesh.faceCentres()[oppFaceI];
        // get coordinates of centre of patch at the boundary face
        vector patchFaceCentre =
            mesh.faceCentres()[faceI+patch().patch().start()];
        // distance to opposite face
        scalar yn = mag(patchFaceCentre - faceCentre);
        // dimensionless distance to opposite face, using k at the opposite
        // face
        scalar yStarn = yn*sqrt(kSurface[oppFaceI])*rhon/mun;
I think one problem that I have was to define kSurface at first
const surfaceScalarField& kSurface = fvc::interpolate(k)
this lead to bogus readings of the value that I actually wanted to read.
~roman
Setting an external B0_x field in MHD module fferroni FLUENT 11 August 1, 2022 08:20
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
How to get the velocity field from the pressure field Hermano Main CFD Forum 2 November 29, 2011 08:32
automatic call a function in a program gerado OpenFOAM 9 June 29, 2009 02:30
2D CFD code using SIMPLE algorithm bfan Main CFD Forum 3 June 22, 2002 22:01
