Conversion to fvscalar matrix equation
Like Tree2Likes
  • 2 Post By mkraposhin
Old   December 11, 2013, 11:06
Unhappy Conversion to fvscalar matrix equation
AJ
Aj Nair is on a distinguished road
Dear Fomers
Can you guys help me to convert this energy equation to fvscalar matrix equation, i am getting frequent errors in this part of program.
Aj Nair is offline   Reply With Quote
Old   December 11, 2013, 11:43
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
forAll(A,i)
                    A[i][i] = pEqn.diag()[i];                // inserting diagonal elements in A
                    b[i]    = pEqn.source()[i];                // and in b
                const lduAddressing& addr = pEqn.lduAddr();
                const labelList& lowerAddr = addr.lowerAddr();
                const labelList& upperAddr = addr.upperAddr();
                forAll(lowerAddr, i)
                    A[lowerAddr[i]][upperAddr[i]] = pEqn.upper()[i];
                    A[upperAddr[i]][lowerAddr[i]] = pEqn.lower()[i];
                forAll(p.boundaryField(),I)
                    const fvPatch &ptch=p.boundaryField()[I].patch();
                    forAll(ptch,J)
                    int w=ptch.faceCells()[J];
                    A[w][w]+=pEqn.internalCoeffs()[I][J];
                    b[w]   +=pEqn.boundaryCoeffs()[I][J];
mkraposhin is offline   Reply With Quote
Old   December 11, 2013, 18:36
AJ
But Matvej, i have attached an equation below.I had changed that equation as
fvm::ddt(T)+ ((fvc::grad(U))*T)-(lambda\(Cp*rho))*fvm::laplacian(T)
ignoring the epsilon. Is the above equation equivalent to which i attached .Because i get errors when i use this in TEqn
Old   December 12, 2013, 03:56
Bernhard
Bernhard is on a distinguished road
Uhm, which errors?
Normally you would discretize the convective term with fvm::div(phi,T).
Have a look in the, for example, buoyantPimpleFoam solver. The h-equation is very similar to your T-equation.
Bernhard is offline   Reply With Quote
Old   December 12, 2013, 09:32
AJ
Bernhard, i have uploaded a formula pic in my first post.I got that from a journal.I wanted a fvscalar matrix equation equivalent to that.can u please go through tat equation and give me some suggestions.
Old   December 13, 2013, 11:17
mkraposhin's Avatar
Matvey Kraposhin
Hi, Aj Nair!
My last post was about how to convert from your OF matrix format to 2D array. Now i see, that You are missing some basics of OF.
The problem that you are experiencing, is that OF uses conservative integral solution. Let's think you have equation
Then, You must convert this equation to conservative form:
But, OF works with integral equations, thus, you have to convert to integral balance:
If you will use mean theorem, without second order terms you can write:
By splitting terms at the r.h.s You will get:
Old   December 13, 2013, 11:28
mkraposhin's Avatar
Matvey Kraposhin
Now, if lambda, rho and Cp are constant, You convert Your equation to:
You can find all equations here:
T-equation-from-cfd-online.pdf
Last equation can be discretized with OF:
volScalarField kappa = lambda / rho / Cp;
fvScalarMatrix TEqn
    fvm::ddt(T)
    fvm::div(phi,T)
    fvm::Sp(fvc::div(phi), T)
    fvm::laplacian(kappa, T)
    + (gamma / Cp) * dEpsilonOverDt
Please, remember, that we used second order approximations to get this equation, so You don't need schemes with order, higher then 2. You can use my first post in this thread to analyze resuling matrix TEqn (like pEqn)
smraniaki and daire6 like this.
Old   December 15, 2013, 02:11
AJ
Thanks a lot Matvej, i will come back to you, if i have any doubt
Old   December 15, 2013, 02:25
AJ
Sorry for the delay in reply, thanks again Matvej
inverse of a matrix or solution of implicit equation romant OpenFOAM Programming & Development 4 August 6, 2013 09:02
About theory:how to get the pressure equation when solving u-p simultaneously? lzw2003 Main CFD Forum 8 April 8, 2012 22:13
continuity equation Rafal Main CFD Forum 4 November 29, 2006 09:27
Poisson equation vs continuity equation DJ Main CFD Forum 1 August 5, 2004 20:01
Boundary conditions in a Poisson's equation? vincent Main CFD Forum 4 April 16, 1999 02:19
