Creating time/temp dependant variable
Like Tree4Likes
  • 1 Post By sur4j
  • 1 Post By maybee
  • 1 Post By maybee
  • 1 Post By maybee
Old   December 21, 2013, 14:59
Default Creating time/temp dependant variable
sur4j is on a distinguished road
I am trying to create a time and temperature dependant variable within the solidDisplacementFoam solver, currently the value is defined as a constant volScalarField as shown:
volScalarField mu("mu", E/(2.0*(1.0 + nu)));
I need this to change in the following way: When reaching a certain temperature it should start increasing at a constant rate in time up till reaching a final value at which it stops increasing. I attempted to do this by adding the following code into the main .C file:
forAll(mu.internalField(), cellI)
if(T.internalField()[cellI]>330){
 mu.internalField()[cellI] = 10e+06;
mu.correctBoundaryConditions();
mu currently is set to a constant value upon reaching 330K temperature, how would I make this so that it increases at a constant rate in time and stops at a new larger value of mu when reaching the temperature?
Any help at all with this problem would be greatly appreciated. Thank you.
sur4j is offline   Reply With Quote
Old   December 22, 2013, 06:20
maybee is on a distinguished road
hi,
I am not sure if it will work like this, but my idea would be something like this:
if(T.internalField()[cellI]>330 && T.internalField()[cellI]< LIMITTEMPERATURE )
 mu.internalField()[cellI] = FUNCTION FOR mu DEPENDENT ON TEMPERATURE T;
else
Please note that this is not a 100% save solution since if the temperature rises over the LIMITTEMPERATURE the default value within else {} is used what should be wrong at this point, but you could solve this easily with a else if and afterwards a else .
greetings
maybee
maybee is offline   Reply With Quote
Old   December 22, 2013, 07:11
Thank you for the reply. For this simulations I need to make it time dependant, there is no upper limit for the temperature. What I am trying to do is find out how to make the "FUNCTION OF mu DEPENDANT ON TIME", so that when the point reaches the specified temperature in the IF statement the variable increases at a certain rate in time for example:
IF "this point reaches 330K"{
"start increasing mu at this point at some rate for the next x seconds"}
or you could even say something such as "start increasing mu at this point at some rate until reaching the value of mu=x at which point stop any further increase in mu" I attempted to program the temperature dependence in the IF statement I had wrote but don't know where to start with the time dependence.
Old   December 22, 2013, 07:51
hi,
ok I think I have understood you now. Since the time loop is the master loop of every solver, you will have to tell the compiler by your code that after "T => 330" is reached mu takes for the next X seconds the value
mu.OldTime() + specified value e.g. funciton
So, for the value of mu you will have to store the mu field (if not done yet) and take the old field and add your specified value (function).
The next problem will be the time you have to arrange. For example if you want to do this procedure shown in the above code for 5 seconds and the time step is 1 second you will have to tell the compiler something like
if the temperature 330 was reached do the above for the next 5 seconds (5 time steps)
Obviously it will be not done easy like this, especially if you have a variable time step (what I don't know).
My basic idea is to work with the GLOBAL variables "bool TempReached" and some kind of "count variable TempReachedTime" under which you save the time when T >= 330 was reached plus the time you want to increase mu (in the example 5 seconds).
Afterwards you add some code like
if (TempReached)   //TempReached is to be set true when T >= 330 is reached
{                            //and after the time your increasing has to be finished to be
                             //set false again
if (actualTime <= (TempReachedTime + Time to increase mu) )
 mu.internalField()[cellI] = mu of internalField of oldTime + specified value;
else
 other value for mu
Note, this is just a basic idea plus it should only work for constant timesteps. When having variable time steps it gets more complicated.
Hope this helps you a little.
Old   December 22, 2013, 13:27
hi maybee,
Thank you so much for your help. I am a beginner in programming so am still trying to get my head around how the code works and how to add it to the solver. Just to confirm, will this code do the following: wait until a point inside the body reaches 330K temperature then starts increasing mu at that point at a set rate for say 5 seconds and then stop increasing mu an further?
You mentioned I would have to store the mu field, this has not already been done, does this mean that I will have to create an array to store all of the values? Will the following link cover most of what I need to know? http://www.cplusplus.com/doc/tutorial/
maybee likes this.
Old   December 22, 2013, 14:50
hi again.
I don't know what you mean by wait, but the simulation will proceed with the content of the else {} parenthesis until the temperature T is equal/higher than 330. But you brought up an important point: Since you have to differenciate between the several mesh-cells in your geometry my code does not fullfill this task. Therefore you would have to create a code more like this:
mu = mu.OldTime() + specified value e.g. funciton
If in a CELL the temperature 330 is reached do the above for this CELL the next 5 seconds (5 time steps)
Perhaps something like this could work (now it becomes funny ):
forAll(mu.internalField(), celli)
if (TempReached [celli])   //TempReached is to be set true when T >= 330 is reached
                                   //set false again
if (actualTime <= (TempReachedTime[celli] + Time to increase mu) )
if (Temp [cellI] >= 330)  //this assures that the temp is still equal/above 330
else
mu.internalField()[celli] = other value
This means you have to implement several lists when using this solution:
-> for every cell you need a own bool TempReached, therefore a List of bools (or an arrat like you would say)
-> for every cell you need variable TempReachedTime, therefore a List of Times
-> I guess the List of temperatures for each cell already exists. [Should be a GeometricField]
For the first part see: http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
For you link:
The link covers the basics of c++ programming. It is absolutely necessary to understand the most of it. In the OpenFOAM code can be found much more, but this you should search for if needed for your project and after you know about the basics of programming.
Please note that the basic solution idea I have given is probably just one way and perhaps not even the best. I am not a computer scientist, nor I am an expert when it comes to the OpenFOAM code, but I think my idea or something similar to it could work.
sur4j likes this.
Old   December 23, 2013, 14:01
hi Maybee,
Again, thank you for the very helpful detailed reply, I greatly appreciate the time you are spending with me on this.
I think that I have gained a better understanding for the code now and have attempted to write the global variable arrays for TempReached and TimeTempReached:
int TempReached [size];//how to get the maximum value for cellI to get the "size" value?
int TempReachedTime [size];
	TempReached [cellI] = true;
	TempReachedTime [cellI] = currentTime;//how to get the current time?
I then added the following into your code inside the loop to make the TempReached value false when reaching the required value for mu:
if ((actualTime - TempReachedTime[cellI]) => Time to increase mu){
TempReached [cellI] = false;
Firstly, will this code work? Also, I started thinking about what would happen when the time loop changed to the next time value, would the values in the for loop previously written for the global variables be overwritten? If so, would I be required to create multidimensional arrays for the global variables in which the time is taken into account?
Thanks.
Old   December 23, 2013, 14:59
This should be a bool array not an int. You will have to look up in the object in which the cells are stored and search it for the number of cells. E.g. generally the class for this object should be fvMesh: http://foam.sourceforge.net/docs/cpp/a00741.html
If you are lucky a method for getting the number of cells is already existing within the class, if not you have to find a own code solution...
I just noticed this won t be this easy. I guess you will have to define a "twodimensional array" where the first array is for the cells and each cell has it own second array in which the times will be stored when Temp 330 is reached, since the Temp could be reached more than once. Furthermore you ll have to build up some mechanism that guarantees that always the right time is chosen out of the second array for the if condition...
I see you learned some basics, actually it would perhaps be better just to add one else in my code:
if (Temp[celli] >= 330)
TempReached [celli] = true; // added mechanism to set cell bool of bool array true !
                                   //set false again
else
TempReached [celli] = false;
else
Note, I also added a mechanism to set the cell booleans true if temp >=330
No, the code will not work at the moment.
Aside from what I have posted you will surely have to check all the names I used in the basic IDEA, e.g. the object "actualTime" probably does not exist in this way -> you will have to search in the class Time object for it with something like "runTime.getTime" (in the solver I am working with the time object is called runTime -> look up your solver file).
If the variables are declared/defined outside the time loop
//GLOBAL VARIABLES HERE DECLARED
while(runTime.loop)
they will always store the last value they get within the loop. Note, I tested this with a while loop:
#include <iostream>
int main()
int i = 0;
int GLOBAL = 5;
	while (i < 10)
GLOBAL ++;
i ++;
	std::cout << GLOBAL << std::endl;
	std::cout << i << std::endl;
	return 0;
Just test it yourself if you like to .
About the array see what I have written above.
Old   December 23, 2013, 15:21
Thanks for the fast and VERY helpful reply. Quick question, the simulations I plan on running with this solver are simple heat transfer simulations where a constant temperature BC is set at the walls therefore, I think that the temperature should only reach 330 once. For this simulation would the two dimensional array you mentioned above be necessary or could I continue using a simple 1D array?
Old   December 23, 2013, 15:32
In this case I guess a 1D array should be enough. Obviously this will limit your solver to a case where temp >=330 only one time is reached within the process.
Aside from this note, that you will have to define a mechanism that stores the time when temp >= 330 is reached, but exactly the time when it is reached the first time, since you want to use the "first occure time" for "TempReachedTime[celli]" within
sur4j likes this.
Old   December 23, 2013, 17:03
Is [cellI] an array? If so to find the size of the [cellI] could I not use the following simple code?
(sizeof((celli))/sizeof((celli[0])))
Where the size of the entire array is found in bytes and then divided by the size of a single element of that array to get the total number of elements? and then maybe to stay safe I could add a bit to it to make sure that there is enough elements.
Or if not could the following be used?
int a;//this sits outside the time loop
forAll(mu.internalField(), celli) {a++;}
Then use the value for "a" to define the size?
Old   December 24, 2013, 08:21
Hmmm, no . An array is for example
where int defines the type of the array which means the elements of the array are of type int, where the array is "TempReachedTime" and where within [size] you define the size of the array which means how much elements are inside the array. If you leave it empty like [] the size will be chosen dynamically as needed, but generally it should be better to give the array the right size.
Furthermore the forAll loop shows how you can access the different elements of the array and therefore an iterator (with the name celli) is used which number is increased with every loop pass, e.g. in the first pass celli is 0 therefore the first element of the array "TempReachedTime" is accessed, in the second pass celli is 1 therefore the second element of the array "TempReachedTime" is accessed and so on.
But these all are c++ basics, if you can't understand it from tutorials use a c++ forum or a good book. See:
https://www.google.com.tr/search?q=c...glish&safe=off
You can also switch between tutorials if one doesn 't explain a content good enough for you...
greetings
maybee
Old   December 24, 2013, 10:24
Thank you for the reply. I did not realise that you could define a dynamic array by simply leaving the brackets empty, this will make things much simpler for me. I have started learning more about C++, I had read a lot about it in the past but never really understood it, I think this was because I never written the code and only looked at examples done by others therefore, I am going to write some code, to start off I wanted to see if an alternative method I had a while back to program this solver would work.
or
We had mainly concentrated on the first quote but I think it may be easier coding the second method, I have tried to write the code for this:
int deltaMu = the amount to increase mu each time step
    if(mu.internalField()[cellI]<(mu+(deltaMu*5))){
        mu.internalField()[cellI]+=deltaMu
else{
   mu.internalField()[cellI] = mu;//mu defined in previous code
Would the above code work for this simulation?
EDIT: I added this code into the solver and it seems to work, do you notice anything that has been missed in this code? Would you suggest any improvements?
Thanks
Old   December 24, 2013, 11:13
Your code:
else{
Hi, this will work, but you have to think about the consequences... . You could define your own mu let us say muSTATIC = 2; (just as example). But let us go through the simulation to see what will happen:
1. Temp goes up to >=330 and mu.internalField() is increased like you want to for a specific time in every timestep.
2. Now the specific time is over -> what possibilities do we have:
2.1 The temperature is still >= 330 -> mu is increased again
2.2 The temperature is under 330 (e.g.325) -> mu instantly "jumps back" to another value -> from physical view strange
My idea would be now : why not develop a mathematical function for mu in dependence of the temperature -> With this you could achieve a much more logical solution from a physical view (which is the important view here ).
For example:
int muMAX = yourvalue;
    if(mu.internalField()[cellI]< muMAX) //checks if final value for mu is reached
        mu.internalField()[cellI]+= muBASIS + (mu per Kelvin) * Temperature // 1Grade Function
else //in this else: mu for the limittemperature must be defined
   mu.internalField()[cellI] =muMAX // in other words "maximal mu"
Surely it has not to be a linear function 1 grade used for mu...
Plus you won't need any any other variables like arrays ...
sur4j likes this.
Old   December 24, 2013, 12:05
Thanks for the improvements. Just out of interest, I had a problem when running the code I had previously written. When I use the following part of my code for example the solver compiles fine:
if(mu.internalField()[cellI]<(9e+06+(deltaMu*3)))
However, when I change the constant to the defined value mu as shown, I get an error:
if(mu.internalField()[cellI]<(mu+(deltaMu*3)))
This is strange because it is defined the same way in the equations inside of the same file, for example in the DEqun:
fvm::laplacian(2*mu + lambda, D, "laplacian(DD,D)")
mu itself is defined as shown in another header file as shown below. This header file is included at the start of the main code.
If it helps, the error I am getting when using wmake on the solver is the following:
Making dependency list for source file cureFoam.C
SOURCE=cureFoam.C ;  g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam222/src/finiteVolume/lnInclude -ItractionDisplacement/lnInclude -IlnInclude -I. -I/opt/openfoam222/src/OpenFOAM/lnInclude -I/opt/openfoam222/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linuxGccDPOpt/cureFoam.o
cureFoam.C: In function ‘int main(int, char**)’:
cureFoam.C:82:46: error: no match for ‘operator<’ in ‘(& mu.Foam::GeometricField<Type, PatchField, GeoMesh>::internalField [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, Foam::GeometricField<Type, PatchField, GeoMesh>::InternalField = Foam::Field<double>]())->Foam::Field<double>::<anonymous>.Foam::List<double>::<anonymous>.Foam::UList<T>::operator[] [with T = double, Foam::label = int](cellI) < Foam::operator+(const Foam::GeometricField<double, PatchField, GeoMesh>&, const scalar&) [with PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, Foam::scalar = double]((* &(Foam::scalar)(deltaMu * 3)))’
cureFoam.C:82:46: note: candidates are:
/opt/openfoam222/src/OpenFOAM/lnInclude/dimensionedType.C:586:6: note: template<class Type> bool Foam::operator<(const Foam::dimensioned<Type>&, const Foam::dimensioned<Type>&)
/opt/openfoam222/src/OpenFOAM/lnInclude/VectorSpaceI.H:677:13: note: template<class Form, class Cmpt, int nCmpt> bool Foam::operator<(const Foam::VectorSpace<Form, Cmpt, nCmpt>&, const Foam::VectorSpace<Form, Cmpt, nCmpt>&)
readSolidDisplacementFoamControls.H:3:11: warning: unused variable ‘nCorr’ [-Wunused-variable]
readSolidDisplacementFoamControls.H:5:8: warning: unused variable ‘convergenceTolerance’ [-Wunused-variable]
make: *** [Make/linuxGccDPOpt/cureFoam.o] Error 1
As mentioned, this error does not appear when compiling with a value such as 9e+06 instead of mu so I think that things such as "error: no match for ‘operator<’" are not the real errors and are just created because of the way mu is defined. How would I define mu so that this error does not occur?
Old   December 24, 2013, 13:46
hi,
I am not sure, but when you look at
this should be some kinde of field (array) since you access the mu of the internal field of each cell. So I guess if you use the whole field for some calculation like probably here
it is okay to use the field, but not in this case
mu+(deltaMu*3)
where you would add an int to a field and this operation perhaps is not defined.
However, this is my guess .
Old   December 24, 2013, 14:01
Thanks for your help, I have a few more questions but will dedicate a new thread to them.
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 04:35
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 04:27
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
