Transfer elements of dictionary into List<dimensionedScalar> |
February 25, 2014, 12:07 |
hi,
in one of my files, let s call the file "properties" I have a subdict like Code:
ValueV1 { V1S1 [0 1 1 0 0 0 0] 888888; V1S2 [0 1 1 0 0 0 0] 7777; . //no constant number of entries . . } I tried something like Code:
List<dimensionedScalar> List_V1 = properties.subDict("ValueV1"); Code:
error: no match for ‘operator=’ I know that I can stream the subdict into an object of class dictionary or create a reference to it like Code:
const dictionary& subDict = properties.subDict("Value1"); greetings maybee Last edited by maybee; February 27, 2014 at 04:57. |
February 26, 2014, 07:09 |
I would think that this is not possible since the subDict type has some other properties compared to the List type. Maybe you should try to run a forAll loop over the entries of the subDict and then assign them to a List<dimensioned scalar>. But are these really all entries of type dimensionedScalar?
If that is not possible then you can maybe just read the scalar values out of the subDict with the readScalar() function. Can't guarantee that this works, but maybe something like this: Code:
//Get name of dictionary before List<dimensionedScalar> list(dict.size()); forAll(dictName, i) { //Get name of actual entry before dimensionedScalar listElement = (entryName, dimensionset(0, 1, 1, 0, 0, 0, 0), readScalar(properties.lookup(entryName))); list[i]=listElement; } |
February 27, 2014, 04:55 |
hi,
thx for the help. Unfortunately I can t use your code since the number of elements/entries within the subdict is not constant. Therefore I can t write the code using the list entries. I edited my intitial quesiton now. Edit: I guess I have found a solution that works like this: Code:
wordList VALUES ( properties.lookup("VALUES") ); forAll(VALUES, i) { const word& Current = VALUES[i]; dictionary& subDict_Values = properties.subDict("TheValues"); List_Values[i] = dimensionedScalar(subDict_Values.lookup(Current)); } greetings maybee Last edited by maybee; February 27, 2014 at 10:05. |
Heat transfer coefficient - what is waht | Stan | FLUENT | 28 | December 29, 2021 16:29 |
Fluent Tutorial on Heat transfer | Far | FLUENT | 15 | July 29, 2017 15:31 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
additional variable mass transfer in CFX5.6 | john | CFX | 1 | February 14, 2004 00:30 |
