Gerhard Holzinger
Rep Power: 28 ![]() ![]() |
I have a question to the following piece of code taken from interDyMFoam.C of OpenFOAM-2.2.x.
In the curly braces the variable Urel is declared and used inside the if-statement. Where is Urel used in this solver? It is neither passed to any method as an argument nor should it be accessible outside the block within the curly braces. So, of what use is Urel? Code:
scalar timeBeforeMeshUpdate = runTime.elapsedCpuTime(); { // Calculate the relative velocity used to map the relative flux phi volVectorField Urel("Urel", U); if (mesh.moving()) { Urel -= fvc::reconstruct(fvc::meshPhi(U)); } // Do any mesh changes mesh.update(); } if (mesh.changing()) { |
Sandeep Menon
Rep Power: 25 ![]() |
As the comment suggests, a relative flux field is calculated internally by dynamicRefineFvMesh for mapping purposes.
When the mesh changes, all fields in the registry (including the Urel field) are mapped auto-magically. |
Gerhard Holzinger
Hi, thanks for the answer.
What is still not clear to me is, where Urel is used. As it is declared within this block I assume it is not in use before this block. To me it seems that Urel is nowhere used, but probably I am just confused. |
Chris Sideroff
Rep Power: 22 ![]() |
It's created simply for recomputing the fluxes on the newly refined mesh. In the dynamicMeshDict, under the correctFluxes entry you'll find a list of pairs. Those are mappings of the velocity fields to the fluxes. Since the flux phi is relative to mesh motion, it needs a relative velocity mapped to it. Since a relative velocity isn't stored anywhere else, it's computed where you point out. That's all Urel is used for.
Capabilites of interDyMFoam | kilroy | OpenFOAM | 2 | April 29, 2013 12:29 |
small question about the functionalities of topological changes in OpenFoam | ngj | OpenFOAM Running, Solving & CFD | 2 | February 28, 2013 10:02 |
Question Re Engineering Data Source | imnull | ANSYS | 0 | March 5, 2012 13:51 |
internal field question - PitzDaily Case | atareen64 | OpenFOAM Running, Solving & CFD | 2 | January 26, 2011 15:26 |
Poisson Solver question | Suresh | Main CFD Forum | 3 | August 12, 2005 04:37 |
