Rep Power: 14 ![]() |
hi,
I have looked up now several multiphase tutorial cases and within the 0 folders are some kind of phase fraction fields (alpha) already stored (E.g. tutorial case bubbleColumn of multiphaseEulerFoam.) My questions are... 1. How can the fields (internal fields) have been described without running "blockMesh" before and therefore not knowing the mesh-structure and cell-numbers? 2. If this is some kind of special procedure - how does it work and where are the fields read and stored in multiphaseEulerFoam? Edit: 3. Most importantly: Can I access the phasefraction fields of each phase by doing Code:
PtrDictionary<phaseModel>& PhasesPtrDictionary = fluid.phases(); wordList Phasenames ( PhasesPtrDictionary.toc() ); for (int currentLoopPass = 0; currentLoopPass <= 5; currentLoopPass++ ) { word actualPhase = Phasenames[currentLoopPass]; phaseModel* ActualPhase = PhasesPtrDictionary.lookupPtr(actualPhase); volScalarField& AlphaActualPhase = *ActualPhase; } greetings maybee Last edited by maybee; March 12, 2014 at 09:19. Reason: new question |
Chethan Mohan Kumar
Rep Power: 0 ![]() |
In regard to your 3rd question: You can definitely access the zone volumes. In fact it is automatically displayed onto your log during run time. The only pre- requisite is that, you need to have defined cell zones in your mesh. You can define it in your blockMeshDict when you define your block. You can verify the existence of your zones in the poly mesh directory after running blockMesh. Another hint for tracking cell zone based values would be through the use of libsofunctionobjects in controlDict, again a cell zone must be defined while creating the mesh. Hope this helps. Regards, Chethan |
#3 | |
a reconstructPar issue | immortality | OpenFOAM Post-Processing | 8 | June 16, 2013 11:25 |
an odd(at least for me!) reconstructPar error on a field | immortality | OpenFOAM Running, Solving & CFD | 3 | June 3, 2013 22:36 |
Missing fields in reconstructPar | flowris | OpenFOAM | 1 | July 9, 2010 02:48 |
PostChannel | maka | OpenFOAM Post-Processing | 5 | July 22, 2009 09:15 |
Mapping fields | hsieh | OpenFOAM Pre-Processing | 3 | September 14, 2005 19:56 |
