make a dimensionedScalar to be volScalarField
Like Tree3Likes
  • 3 Post By alexeym
Old   April 2, 2014, 04:39
Default make a dimensionedScalar to be volScalarField
Dongyue Li
sharonyue is on a distinguished road
I wanna make the diameter of the particle to be variable. Before I revise the code, d_ is a dimensionedScalar, locates in /opt/openfoam222/applications/solvers/multiphase/twoPhaseEulerFoam/phaseModel/phaseModel
//- Characteristic diameter of phase
        dimensionedScalar d_;
Then I change it into:
        volScalarField d_;
volScalarField& d()
            return d_;
    d_
        IOobject
            "d" + phaseName,
            mesh.time().timeName(),
            mesh,
            IOobject::MUST_READ,
            IOobject::AUTO_WRITE
        mesh
I wmake this phase.C successfully. But when I wmake this dragmodel as follows:
Foam::tmp<Foam::volScalarField> Foam::GidaspowSchillerNaumann::K
    const volScalarField& Ur
) const
    volScalarField alpha2(max(scalar(1) - alpha1_, scalar(1e-6)));
    volScalarField bp(pow(alpha2, -2.65));
    volScalarField Re(max(alpha2*Ur*phase1_.d()/phase2_.nu(), scalar(1.0e-3)));
    volScalarField Cds
        neg(Re - 1000)*(24.0*(1.0 + 0.15*pow(Re, 0.687))/Re)
      + pos(Re - 1000)*0.44
    return 0.75*Cds*phase2_.rho()*Ur*bp/phase1_.d();
it said:
SOURCE=dragModels/GidaspowSchillerNaumann/GidaspowSchillerNaumann.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam222/src/finiteVolume/lnInclude -I../phaseModel/lnInclude -IlnInclude -I. -I/opt/openfoam222/src/OpenFOAM/lnInclude -I/opt/openfoam222/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/GidaspowSchillerNaumann.o
dragModels/GidaspowSchillerNaumann/GidaspowSchillerNaumann.C: In member function ‘virtual Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::GidaspowSchillerNaumann::K(const volScalarField&) const’:
dragModels/GidaspowSchillerNaumann/GidaspowSchillerNaumann.C:74:47: error: passing ‘const Foam::phaseModel’ as ‘this’ argument of ‘Foam::volScalarField& Foam::phaseModel::d()’ discards qualifiers [-fpermissive]
dragModels/GidaspowSchillerNaumann/GidaspowSchillerNaumann.C:82:51: error: passing ‘const Foam::phaseModel’ as ‘this’ argument of ‘Foam::volScalarField& Foam::phaseModel::d()’ discards qualifiers [-fpermissive]
make: *** [Make/linux64GccDPOpt/GidaspowSchillerNaumann.o] Error 1
So in this code above, I only make a dimensionedScalar to be a volScalarField. If I delete this phase1_.d(), all is okay. How should I handle this?
Actually my thought is very simple, in twoPhaseEulerFoam, particle's diameter is constant. you can set it in your transportDict. Well cua I wanna implant PBM into it, so this diameter should be variable. So I wanna implant PBM step by step. At first I should change this constant diameter to be changeable. This is why I revise the code.
sharonyue is offline   Reply With Quote
Old   April 2, 2014, 05:23
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
you've changed d_ in header file but did not change initialization of the field in constructor, it still initialized like (phaseModel/phaseModel/phaseModel.C):
    d_
        "d",
        dimLength,
        dict_.lookup("d")
or did you also change this piece of code?
Problem appears here (interfacialModels/dragModels/GidaspowSchillerNaumann/GidaspowSchillerNaumann.C):
it tries to use your strangely initialized d_ volScalarField and fails.
alexeym is offline   Reply With Quote
Old   April 2, 2014, 05:33
Dongyue Li
Originally Posted by alexeym View Post
    d_
        "d",
        dimLength,
        dict_.lookup("d")
Yes, I also changed that. So phase.C is wmaked successfully. But when I wmake GidaspowSchillerNaumann.C, it failed.
In this code, phase1_.d() is dimensionedScalar. but when I change it into volScalarField, it can not be wmake.
You get my point, Thanks anyway.
Old   April 2, 2014, 05:41
Alexey Matveichev
Well,
you can change
volScalarField& d()
    return d_;
to
const volScalarField& d() const
    return d_;
as obviously you don't want interfacial model to change it. Or you can return tmp<volScalarField>:
tmp<volScalarField> d() const
   return d_;
cause volScalarField has this constructor:
GeometricField (const GeometricField< Type, PatchField, GeoMesh > &)
as you are trying to use it with just volScalarField& compiler complains about discarded const specifier.
PonchO, sharonyue and wht like this.
Old   April 2, 2014, 05:44
Dongyue Li
Well,
you can change
volScalarField& d()
    return d_;
to
    return d_;
   return d_;
Neat! it is solved !!!beautiful!Thanks bro.
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 09:21
Problem with pow and volScalarField _Stefan_ OpenFOAM Programming & Development 15 April 14, 2019 22:20
changing a volScalarField to a dimensionedScalar wschosta OpenFOAM Running, Solving & CFD 5 May 6, 2015 10:20
multiplicate all elements of volScalarField with scalar to get new volScalarField maybee OpenFOAM Programming & Development 2 February 18, 2014 15:43
Confused about how OF handles operation between volScalarField and dimensionedScalar Edy OpenFOAM 3 September 30, 2010 10:07
